WD serial number
WDmatt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDmatt Quote  Post ReplyReply Direct Link To This Post Topic: WD serial number
    Posted: 23 May 2020 at 4:34pm
I just bought a WD, and the serial number is 209286. I know I'm not reading it wrong, and the serial numbers ended at 131,273 in 1953. I'm almost 100% positive that the tractor is a WD, not a WD-45. How is my serial number possible?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 6:07pm
It would seem that someone replaced the complete 'rear end assembly' with one from a WD-45.
Does it have a Curved Shifter ?
BTW where are you getting the Serial No. from on the tractor ?
Edited by Gary - 23 May 2020 at 6:12pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 10:35pm
That # is a parts #.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 1:14pm
Serial # is located on left rear housing and is stamped in not cast in.---look again at your tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDmatt Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 8:35pm
Yeah, it's stamped in, I just miswrote cast on my post. It does have a curved shifter
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 9:19pm
Matt... your engine... look at both sides of the block. Are both sides smooth, or does ONE side of the block have a large metal plate with lots of bolts holding it on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 9:35pm
I did not do the research to be able to help you with the serial number. But I will throw this in the mix. We have a WD that had the rear end changed and does not have the original number on the back. I am still kicking myself for not getting the original serial number off the casting we scraped!
Edited by Sugarmaker - 25 May 2020 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDmatt Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:53am
The engine is a WD-45 engine. I'm starting to think that the tractor is a WD-45. My neighbor who I bought it from swears up and down that it is a WD. The hood has 2 WD decals on each side, from previous bad repaints. Maybe the hood was replaced? In not sure. Other than the serial number and plate on the right side of the engine, I don't know anymore differentiating characteristics.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:30am
That would be a 1955 WD45 if all else is in agreement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 11:07am
Engine serial number is behind the carb/air cleaner hose and would read 45-XXXXXX-G. If it is a WD engine it would read W-XXXXXX-G or P.  If there is no serial number, the block has been replaced one time in the past and no one ever stamped a s/n in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 3:37pm
one of my 45's came up as a 55 and the parts frame tractor came up a 56.
