d-14 hydraulic hose replacement |
tractorboy
Joined: 03 Oct 2009 Location: southern Va Points: 478 |
Topic: d-14 hydraulic hose replacementPosted: 25 May 2020 at 12:52pm |
Pulled the 14 apart to get to hyd cyl. It had the usual hyd. compartment going empty while over filling the diff. Sure enough the ring gear was eating into the hose. I was wondering if a longer hose would let it lay down & stay away from everything ?? Anyone try this?/ Going to the hyd. shop in the morinng thanks keith so va.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 25 May 2020 at 5:31pm |
My thoughts are a longer hose would make it worse. I'm not familiar with the installation though. It may have been installed incorrectly to start with.
tractorboy
Posted: 25 May 2020 at 5:55pm |
On second thought your'e probably right, the more hose the more it's gotta fit somewhere!!! thanks
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54675 |
Posted: 25 May 2020 at 6:04pm |
I would suggest you order the right hose, from Agco, and then measure the length. Then post it on the forum, knowledge base, so we all know how long to have them made...
Posted: 25 May 2020 at 6:29pm |
Someone didn't have it "clocked" right when they installed the manifold/transport valve.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24865 |
Posted: 25 May 2020 at 7:05pm |
When I did 'Troy' , I had local shop( Princess Auto) make the hose WITH a swivel fitting on the 'feed' end not the ram end. THAT made all the difference in the World. I have an officail AGCO hose here, should have returned it .. Custom made hose was 1/2 price of AGCO one... Sure hope you had THREE buckets to catch all the oil... I was wishin I'd had 3....sigh.....
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3153 |
Posted: 25 May 2020 at 7:24pm |
Could be wrong but doesn't Sandy lake also have the swivel end hose ? HTH
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5190 |
Posted: 25 May 2020 at 8:40pm |
Ditto
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 25 May 2020 at 9:39pm |
What does "clocked" mean? Thanks!
WC, CA, D14, WD45
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10869 |
Posted: 25 May 2020 at 9:42pm |
It means turned to correct position with no twist. Twisted is what makes it prematurely fail by rubbing something. Don't twist the stripe running down length of hose. HTH Tracy
TimNearFortWorth
Posted: 26 May 2020 at 8:46am |
Sandy Lake has the seals kit with new hose, proper length and end fittings, reasonably priced to boot.
Give Brenda a call as she knows just what you need and ships quick.
Dave(inMA)
Posted: 26 May 2020 at 8:57am |
Thanks, Tracy. I appreciate the explanation.
WC, CA, D14, WD45
