d-14 hydraulic hose replacement
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-14 hydraulic hose replacement
    Posted: 25 May 2020 at 12:52pm
Pulled the 14 apart to get to hyd cyl. It had the usual hyd. compartment going empty while over filling the diff. Sure enough the ring gear was eating into the hose. I was wondering if a longer hose would let it lay down & stay away from everything ?? Anyone try this?/ Going to the hyd. shop in the morinng thanks keith so va.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 5:31pm
My thoughts are a longer hose would make it worse. I'm not familiar with the installation though. It may have been installed incorrectly to start with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 5:55pm
On second thought your'e probably right, the more hose the more it's gotta fit somewhere!!!   thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 6:04pm
I would suggest you order the right hose, from Agco, and then measure the length.  Then post it on the forum, knowledge base, so we all know how long to have them made...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 6:29pm
Someone didn't have it "clocked" right when they installed the manifold/transport valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 7:05pm
When I did 'Troy' , I had local shop( Princess Auto) make the hose WITH a swivel fitting on the 'feed' end not the ram end. THAT made all the difference in the World.
I have an officail AGCO hose here, should have returned it .. Custom made hose was 1/2 price of AGCO one...
Sure hope you had THREE buckets to catch all the oil... I was wishin I'd had 3....sigh.....
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 7:24pm
Could be wrong but doesn't Sandy lake also have the swivel end hose ? HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 8:40pm
Ditto
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 9:39pm
What does "clocked" mean? Thanks!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 9:42pm
It means turned to correct position with no twist. Twisted is what makes it prematurely fail by rubbing something. Don't twist the stripe running down length of hose. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:46am
Sandy Lake has the seals kit with new hose, proper length and end fittings, reasonably priced to boot.
Give Brenda a call as she knows just what you need and ships quick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:57am
Thanks, Tracy. I appreciate the explanation.
WC, CA, D14, WD45
