D 17 Diesel ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: D 17 Diesel ?
    Posted: 22 May 2020 at 6:09pm
I ran across a '17 diesel at a local farmstead that has primarily older Oliver tractors as "museum" pieces. In the corner I spied some orange and investigated. It was a D 17 diesel with a snap-coupler but had a strange tall lever to the left of the seat and no lever on the right side of the torque tube like our D series had(15 and 17) to disconnect the snap coupler Ermm. Any Idea of the series of this machine ? The owners son says it runs and is curious if there's any value to it. I saw rim mounted wheel weights on it and was N/F. Thanks and have a safe holiday weekend !!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 3:59pm
Shuttle clutch option. It takes the place of the Right side Big Stick.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 6:13pm
Are the '17 diesels "desirable" ?? What prompted my "snooping" was a snap coupler 3 bottom plow sitting in a fence row , never known this particular operation to have ever run AC equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:12pm
I think the 17 diesels are desirable AND a money pit.  When you get done switching or refurbishing an engine block and a cracked cylinder head, you'll then need to go thru the injection pump and injectors. Of course the starter will need to be rebuilt and two fresh batteries for good ( as good as they are) starting. Then, the engine is done and on to the rest of the tractor.
Edited by DrAllis - 24 May 2020 at 7:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 11:51pm
Yeah, that's pretty much how it goes. I did the engine first. Later on I did the pump and injectors. Then it was the transmission and Power Director. The hydraulic pump is next on the list. Still can't buy a new 55 hp tractor for what I've spent on this one though...
I'll add that a pair of 1000 cca batteries with a 2/0 cable to the starter will crank forever, even at -10.
Edited by Brian Jasper co. Ia - 24 May 2020 at 11:53pm
This page was generated in 0.572 seconds.
