H3 Dozer |
Sgilles
Topic: H3 DozerPosted: 09 May 2020 at 4:06pm |
Hello all, new to the forum. I have recently acquired a h3 dozer that has the capability to be a power six way blade. Does anyone know where one could acquire the side to side tilt cylinder? Or an equally heavy replacement? Thanks in advance
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25263 |
Posted: 10 May 2020 at 6:05am |
welcome, sniff ,sniff.. I always wanted an H3.... if you have the cylinder, a shop could rebuild it... may take a few days for an H3 owner to reply...might not be too many. try googling 'allis-chalmers H3 tilt cylinder specs' ??
Sgilles
Posted: 10 May 2020 at 4:03pm |
Thanks for the welcome, the h3 didn’t come with the cylinders for power tilt and side to side blade adjustment. I was looking to acquire originals or find out the specs for the stroke on them similar could find replacement cylinders.
Posted: 10 May 2020 at 4:35pm |
Just have to wait a bit.... I assume the HD3 is the same setup as the H3, and lots of them around..... Someone will probably post a 'link' to a manual..... Jay
NomoreJohnDeere
Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Posted: 10 May 2020 at 10:33pm |
No pics no link
HD3
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 11 May 2020 at 7:56am |
You might try Summerix Implement in Lachine, MI. Speak to Ivan.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
NomoreJohnDeere
Posted: 14 May 2020 at 8:59am |
HD3
NomoreJohnDeere
Posted: 14 May 2020 at 9:01am |
HD3
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 14 May 2020 at 10:03am |
Surplus Center - has many hyd cylinders and you might find something to work .
son has been buying cylinders from them for his skid loader attachments , but he just bought 2 cylinders off e-bay for a special puller he is building - his supplier he used last time said they were out of production - but he found 2 on e-bay $200 cheaper . After they were delivered the other supplier said they were back in stock but $100 higher than last order . So looks like a lot of suppliers are now competing for business - Other thing some hyd shops will build to order for 1 of use |
Hyperpack
Bronze Level Access
Posted: 01 Jun 2020 at 1:14pm |
I have an H3 for many years, If I were looking to add a cylinder there I would put slightly larger one on there. Mine is weak tilting on one direction on really hard ground with a loaded blade.
Hyperpack
Bret (OH)
Joined: 15 Sep 2009 Location: Blanchester, OH Points: 353 |
Posted: 04 Jun 2020 at 5:47am |
might try Thill Track and Tractor in Eau Claire, WI. http://www.thilltractor.com/
