Bad gas |
![]() ![]() ![]() ![]() ![]() Posted: 02 May 2020 at 10:02pm |
Got's some from the local independent owned station last week. Was making delieverys, stopped and filled up, had less than 1/4 tank. I left town and immediately noticed the mpg gauge went from 23.6 mpg down to 17.3 mpg. Thought I might have a flat tire. Stopped and walked around the pickup. When I got behind it, the exhaust stunk so bad I had to walk away from the rear of the truck. The guys get their gas straight from the pipe line. I wonder what they had been pumping thru the line before the load of gas? Apparently didn't get it cleaned out. Truck was running back up to 23.4 on convience store gas today.
we've had that happen here too, always from independent fuel stations. they seem to want to blend chit in the gas to make another buck!
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24763 |
The 'contractor' filled up his Dodge diesel PU with 'cheaper' fuel, maybe 20c/gallon. Well his truck limped home, had it towed to service, $1000+ later, tank,filter and lines,etc. were cleaned out. Yup he got a DEAL on cheap fuel ! |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34265 |
Tank farms are FULL to the rim right now, they are having to deal with longevity of gas they have not for some time. Current 'Reformulated' or even the newly developed sour crude oil forced refining has a Short life in storage as we have all seen where that does equate back to the stored fuel at the refineries. To make it usable in the short term they blend Old distillates with fresh to 'extend' the life cycle while that is at a cost. Cannot add more additives or stabilizing agents to hold it as the current refining process produces a unstable compound that seeks to reclaim a stable less desirable form.
The only other aspect they can do is sell all they currently have, produce MUCH less, store unrefined crude oil wherever they can to use that as little as possible to keep stored refined products levels limited. And yes, that has begun. |
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
I thought this was going to be about the burritos at the gas station, not the gas itself...
weiner ![]() Orange Level ![]() ![]() Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
Bad gas from them too, especially at the rear,,
Real heros wear dogtags, not capes.
i thought they was talking about me! whew!
They WAS!! You was in the back of his truck at the time,,,,,,,,,,,wasn't you? Sneakin over there to get some of that honey he's gots. An maybe stealin goats too? Or maybe you WAS at home, but with a strong Westerly wind,,,,,,,,,like we been havin,,,,,,,he might a just smelt you too.....
