One wire alternator |
1947WC
Joined: 11 Dec 2015 Location: Wisconsin Points: 214 |
Topic: One wire alternatorPosted: 20 Apr 2020 at 1:41pm |
Is there any way to test a 1 wire alternator with a test light it's a positive ground.
Edited by 1947WC - 20 Apr 2020 at 2:11pm |
Jim.ME
Posted: 20 Apr 2020 at 3:36pm |
I am guessing you are talking about checking alternator output. About the only thing I can see a test light will tell you is there is power at the alternator output stud, which it should have at all times on a one wire alternator. You need a voltmeter to see if the voltage changes when it is running. Positive or negative ground makes no difference in that. I have to ask this, Are you sure it is actually a positive ground alternator?
Dakota Dave
Posted: 20 Apr 2020 at 5:57pm |
Take it off and take in and have tested at the auto parts store. If your alternator has been hooked up POS ground your going to need a new one any way. The diodes are blown and it'll have no output. There are specitly shops that will make a POS ground alternator but they are very expensive. Negative ground became the world standard even before 12 volts became the standard voltage.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55302 |
Posted: 20 Apr 2020 at 5:59pm |
Check with a volt meter, at battery. volts running, vs volts not running...
1947WC
Posted: 20 Apr 2020 at 9:01pm |
Thanks Jim.ME
1947WC
Posted: 20 Apr 2020 at 9:08pm |
Thanks Diy.Dave
1947WC
Posted: 20 Apr 2020 at 9:13pm |
Thanks Dakota.Dave
Adam Stratton
Posted: 20 Apr 2020 at 9:24pm |
Touch something metal to the bearing on the back of the alternator. If it magnetized, it is charging, if not it isnt
1947WC
Posted: 22 Apr 2020 at 1:09pm |
I'll try that. Thanks Adam.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25274 |
Posted: 22 Apr 2020 at 1:16pm |
if, IF, the test light was an LED, then yes.....though everyone has a voltmeter. Just be sure the test leads are in properly(red2red,bl2blk) !!! 99.44% of all alternators are NEG ground BTW....
