6V LED LIGHTS
CAPTMARCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Topic: 6V LED LIGHTS
    Posted: 20 Apr 2020 at 12:00pm
Gentlemen,
   I am rounding the corner on the freshening up of my old Allis CA and am wondering if there are good LED cube lights or work lights to replace the junk sealed beams that are falling off of her now.  Any advice is appreciated!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 3:11pm
I got one from Theisen but have not tried it as I also got LED bulb that fits in the original housing from another source. Your charging system needs to be in good working order for it to light up.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 3:29pm
What is a good source for 6v LEDs that fit the original housing?  My 6v system works great, but if there is a better bulb, I'd be all for it.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 4:14pm
I got the lamp and new reflector from Steiner. It is a 6/12 volt lamp that fit the original socket. Ad you can see it is bright but the battery charger is on because the generator and or regulator is not working. Sorry for the OC photo
