53 WD pump controller...?
rmvr53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmvr53 Quote  Post ReplyReply Direct Link To This Post Topic: 53 WD pump controller...?
    Posted: 19 Apr 2020 at 1:39pm
I've had this WD for about 12 years. This is the first "failure" I've had. Was using the tractor last fall for final cleanup around the place when the bucket took off on its own to the top of the rams. It took about an hour before the pressure started to bleed off and the bucket drop sufficiently that I could get the unit back in its "hole" for winter storage.
Well, its time to get to work and I have put off trying to figure out what was wrong so I thought I'd start with the collective knowledge and see if there were ideas.
As an FYI, I started it yesterday and the rams do not move at this point.
thanks
Bill
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 3:54pm
Do you have a manual?
could be something as simple as the control valve falling out of adjustment.
That thumbscrew is turned one way or the other to perform different functions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 4:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 4:26pm
Having a hard time getting the picture sized c orrectly.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 7:58pm
I’m sure glad you were not sideways on a side hill with a bucket full last fall! Try to keep in mind pushing in your foot clutch would have stopped that runaway.
Blue Skies and Tail Winds
                          Dana
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 9:24pm
Sounds like spool valve sticking in pump. Came loose after cooling.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmvr53 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 12:12am
I have the original manual for the tractor. I looked at that page but it didn't seem to apply to the runaway bucket. Also, the thumb screw has enough paint on it it will take a hammer and chisel to move it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmvr53 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 12:14am
Mack
would that spool valve sticking prevent the bucket from moving later?
Edited by rmvr53 - 22 Apr 2020 at 12:14am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:36am
It could prevent it later. Heat causes them to stick most times.    MACK
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:54am
What would cause the pump to be overheated? Maybe by low or perhaps contaminated fluid or just working the tractor hard? Thanks.
Dave
WC, CA, D14, WD45
This page was generated in 0.313 seconds.
