What would you think |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8728 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Mar 2020 at 10:45pm |
Hi everyone.
Want to take hood off 200 to fix cracks around air intake pipe with a stiffener plate. Would it look bad if we painted the hood an grill stuff but not the rest. It has a yearround cab and fenders that's not allis orange. And engine and stuff isn't to bad. Paint hood side panels an grill with new decals or no. Thanks |
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
I think it would be fine to paint it and decal it then do the cab later on. When I bought my 200 it looked so rough I bought new decal set and put on it to make me feel better when I looked at it. Still haven’t gotten around to painting it yet lol
Kiwi ![]() Silver Level ![]() ![]() Joined: 23 Jan 2018 Location: New zealand Points: 390 |
I had IH 574 once and i painted the hood and nose cone i went to a plowing match and someone asked if i had run out of money to finish it
Tractors Allis EB,two C,diesel G
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24727 |
yeah, you'll start with 'just the hood'... and well, 'I'll do the grille' and might as well 'spruce up...... best go by another 200 NOW..... we'll want pictures of your progress...
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3092 |
Do what you want its your tractor.No prizes awarded at least not the ones that count($$$$$$) for the way a tractor looks.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3947 |
I have committed similar sins. Just not to that scale. It looks a bit mottled but I'm reminded of that old song "One piece at a time". Every time I take something apart I want to paint it.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8647 |
My 8070 has good looking side panels. Cab faded orange but the top panel over engine is close to white. Doesn't show from the ground so I get by. It's a lot of work to paint one right....
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3569 |
Mikes, if you’re after originality, try repairing its intake area of hood from its underside. If any welding burns thru topside, just try sanding those spots out & do touch ups. After touching up, try a thorough rubbing compound over entire older original paint. That usually brings back a decent paint luster.
If tractor is a daily user, then painting its grill with new paint now may fade back to looking more original over a year or so? |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54276 |
Did I hear a request? [TUBE]18cW_yHo3PY[/TUBE]
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
I have several units with some parts fixed and painted. Its almost in style! Some folks actually go for that look.
Shows you care, just not that much!:) We need pictures! I like the idea your going to repair something that need fixed. As jay said dont let it get out of control. Some of us go over the edge when we smell and see fresh paint! some examples: The WZ with Nic's wheels. (its going to get its own fancy painted wheels with new tires soon) Our early D17 with new repaired, painted grill, repaired painted lights, and front wheels, Remaining is in its work clothes. ![]() Our (off color) IH 1954 TD6: ![]() Regards, Chris Edited by Sugarmaker - 28 Mar 2020 at 6:36pm |
![]() ![]() The planter I bought off HD6GTOM ![]() One wheel so far For the LoBoy ![]() Edited by plummerscarin - 28 Mar 2020 at 7:55pm |
Those look good to me.
Regards, Chris
I don't seem to have any current pictures. We haven't gotten it out yet, thought we were this week. Was still messing with D17. I will update this with picture when we get her out.
Thanks |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7511 |
All intake pipes coming through the hood should have had reinforcing rings under the hood. The thin sheet metal of the hood weakens as the stack vibrates - hence the cracks you have. When we restored our 175, we made a couple of stiffening rings out of 1/8" steel. Made them a good size to increase the surface area and sandwiched the 2 of them together. We used panel bond to secure them to the underside of the hood - she doesn't vibrate now! If the paint on the tractor is very faded, a freshly painted hood will stick out. The previous owner of my D21 painted the hood and nothing else. See for yourself. |
the parking brake doesn't work, do you get to it with hood off. Anyone know what's the common issue to look for. Thanks
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
If I remember the last time I worked on one........ 25 years ago or more, and it was a 200, the linkage was rusted up. I think I just took right rear side panel off near the park brake lever.
Wink I am a Russian Bot |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5243 |
Interesting thread as I am going to sand blast my hood, fix my grill and fuel tank on my WD and paint those parts. Can’t stand not having decals on my hood. Already bought the decal kit, just need to find the time to do it. She has some leaks that need to be fixed before the rest gets painted.
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1938 |
On the parking brake issue first check the little roll pin in the hadle that holds it to the shaft. then take off the right side rear panel and you and on a 200 they have an extra filler plate under the hood for sound and heat you will have to wiggle out of the way. There you will find a ratchet tooth piece and a little dog piece that sets the brakes. Check the teeth and if they are ok the little dog looses its edge take that off and grind a new edge on it or replace it I have even made a replacement when needed.
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Brings to mind using the 3 word game ![]() |
