Copper fuel line |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Apr 2020 at 11:32am |
I just bought a piece of 5/16” brake line to make a fuel line for my old truck project. It’s the line that goes from the fuel pump to the carb. I also bought a tube bender kit and it made neat work on this project. I cut the end off the brake line and noticed that it appears to be copper lines.
I’ve been told in recent years to stay away from copper on fuel lines. What do y’all say? This brake is a dark army green color on the outside and copper inside. |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
from the net, 1st google search of 'using copper lines for gasoline'... The US Coast Guard requires copper fuel lines on gasoline engines (see here), a google search revealed that copper tubing is used in the refining of gasoline (not as an active element or anything) and OEM lines are often copper lined or made from drawn copper.Nov 17, 2006 dang if it's good enough for them.... USE IT !!! Jay |
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
I had an old guy that sold 9N Fords new tell me not to use steel because of rust developing if the tractor sat with the tank empty. He recommended copper
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5104 |
We use copper on generator fuel lines and have for years. Not the same thing as we use diesel but that's what we use
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5145 |
Come back and tell us when it leaks due to the vibration. Soft plumbers copper will often crack at the flare when use on something with vibration, like in automotive use. Most quality brake lines are a copper alloy that is plated on the outside to prevent rust and will bend easily as well as stand up to vibration.
Use it.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7515 |
I agree with Paul 100%. Plumbing copper is no good, I have never had any problems using 5/16 brake line for fuel on my tractors. Use the tube benders and paint them up, they will look stock!
Gordy ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: SWMI Points: 2533 |
I like to use the braided stainless covered lines for the old cars and tractors easy to use and looks good.
“If you can't explain it simply, you don't understand it well enough”
Gordy, where do you get your line from? Where do you get the fittings from?
Thanks! |
I have just gone to ebay ordered a kit like this.
buy extra copper line fer your still
For hand sanitizer and such???£ That’s a great idea Shamless. |
