F&H wheel weight ? |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2020 at 7:21pm |
Any idea of what # 162 would fit ? They claim 150 #'s per "set" ?? 2 pairs on my local craigslist.
steelwheelAcjim ![]() Orange Level ![]() ![]() Joined: 06 Dec 2009 Location: Blissfield,Mi Points: 1257 |
I always felt they were a "universal" weight that would fit most tractors with a cast center hub, or round spokes with J-hook bolts. What would you like to put them on?
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
A 180
ICTRCTR ![]() Silver Level ![]() ![]() Joined: 17 Nov 2009 Location: Beatrice NE Points: 371 |
161 and 162 f & h wheel weights sandwich together were found mostly on wc allis but will fit different tractors as well.( one fits inside the other )
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4095 |
They will fit your 180. Here's a pic of my (Dad's)
162s are a universial weight I have a set on my wd 45 if your going to stack them you want to put the 161 weights on first they have a lip to center the other weights. I had problems with my 162 without 161s under them I cured the problem by adding another set of bolts and getting real tight.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
I have a D17 with the 161 weights
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
The 161 also have a slightly larger center hole to get a socket onto the six nuts holding wheel center to hub on the WC's
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1154 |
I did not know F&H made a #161 and a #162. I just thought an F&H was an F&H. I'll have to go down to the machine shed and look for a number and see what I find. Great conversation! Learn something everyday. Thanks for bringing up this discussion. Much appreciated!
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3929 |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2036 |
Anyone have a front set of weights that match the rear weights on the WD45?
I would like to find a set of those myself Lon. Have seen them in the book but never in person. Probably a guy in Texas has that several sets.
Never saw the front ones in person either. I found my rear set and I didn't know what I was looking at, but bought them anyway as weights are good property. Then I found them in the book and found they are 375 pounds each. Way cool to have a full set.
Here is a pic from the 'Deep tillage tools' manual. Lists the front weights as 157 Lbs., more than twice as much as the more common 'doughnut' weights.
Hi Dakota Dave: I checked my F&H weights and they all have the #162. When you say this number is a "universal" weight, does that mean they would fit the standard rear wheels on the D-15 and D-17? Nothing special to do with them? Thanks in advance for any thoughts!
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
I know on a D17 you need a 161 weight first (smaller diameter) then you can put on the 162. The 162 will hit the bolts that stick out for the power shift wheels.
