Injector leak
milomilo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Topic: Injector leak
    Posted: 06 Mar 2020 at 7:43pm
My 1986 190XT has #2 cylinder injector leaking fuel at the fuel line connection at the top of the injector. The fuel line nut seemed a little loose, so tightened it about 1/8th of a turn and still leaks. Is the fuel line nut just a metal to metal seal or is there an o ring under the nut?
Edited by milomilo - 09 Mar 2020 at 9:20am
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 8:00pm
There's a rubber sleeve under the nut the squashes out to seal..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 8:00pm
Theres a rubber O ring in that cap. they detieroate over time and can leak, Agco price is 4.50 @ piece, a common diesel shop price is .30 cents,
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 8:58pm
The guy I bought the tractor from did tell me an injector was leaking and the sale came with a bag of o rings for the injectors. Seems this should be an easy fix.
Thanks all for the info.Smile
Edited by milomilo - 07 Mar 2020 at 6:44pm
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 6:48pm
My comment about an easy fix was a bit premature. Expected the o rings to be pretty hard, but took an hour to get one out. It came out in tiny pieces. Used an o ring pointed seal remover. Is there some trick to getting them out a bit faster than an hour each?
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 6:55pm
I must not have used the right search lingo. Do you have a link or a P/N?
Edited by milomilo - 07 Mar 2020 at 7:12pm
Chris (WY)
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:58am
The seal in the return line nut is a rubber sleeve, not an oring. The 190 has a flare on those line ends that won't let the nut slide off. Later series of engines didn't have the flare (not really needed) and you could slide the nut off and remove the old sleeve easily. I usually just burn them. Once the rubber catches fire,it comes out quite easily. You could also file or grind the flare to allow the nut to come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 9:29am
Do you have a P/N for the sleeves?
Chris (WY)
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 9:47am
Agco Part # 70917806 I hold Sleeve With Ice Pick Then Turn Nut It Will Thread Out
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:59pm
Thanks for the tip. I will try that tomorrow.
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 9:18am
Any tips for installing the new grommets over the tube flare?
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 9:48am
I Heat Them With Hot water Or Heat Gun Then Lay Them On Work Bench Then Push Tube Down Into Them
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 10:16am
Seems like some are harder/stiffer than others. Sometimes I've used a tapered punch to stretch them out a little and then slide them on. Hot water for sure will make them more pliable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 7:51pm
Used a small propane torch and melted out the grommets. New grommets are on the way.Smile
Chris (WY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote milomilo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 8:37pm
Grommets installed no leaks. Thanks to all who provided instructions.
Chris (WY)
