Big 4 Tire Changer
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: Big 4 Tire Changer
    Posted: 03 Feb 2011 at 9:41pm
I have a Big 4 Tire Changer that needs a new friction pad on the bead breaker post.  Anyone help with info as where to get parts for this brand?  Thanks...Dale
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 7:42pm
HEY DALE
 DID U GET YOUR PACKAGE FROM LOUISIANA?
dodgemam01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dodgemam01 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 8:13pm
I have the same problem. I have a big 4 older machine center post wont turn. leaks air when I press pedal and if I hold my finger on it will turn alittle.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 10:25pm
Guys those machines were obsolete when I started in the tire business in 1986. Dodgemam, You can rebuild the check valves and make them work. You might have to get inventive to rebuild them. I think a customer of mine bought an inner tube and cut out circles of rubber and glued them to some heavy cloth to rework the valves. His turned after he did this. I do not know what became of the machine. He passed on over 20 years ago. Good luck with them.
Edited by HD6GTOM - 26 Feb 2020 at 10:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 11:51pm
 Mine is probably older than yours....I am the center post....I see that posting is from 9 years ago...I can't even guess how many tires it has changed....The valve got bad and I put a lever type water valve with a bleeder on it...Just keeps on going...  Somebody wanted to change some alloy wheels, so they bought some No-Mar bars for it.
