JB WELD |
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Topic: JB WELDPosted: 02 Feb 2020 at 5:13am |
A few weeks ago there was a discussion about JB Weld. Someone thought that another product like it was as good or better. Dose anyone remember the name of it?
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55294 |
Thanks(1)
Posted: 02 Feb 2020 at 6:21am |
belzona 1111?
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 02 Feb 2020 at 10:04am |
I've used both and have good luck with Belzona as it is easier to machine. They both have a temperature limitation fo bout 500°. There is a JB weld "extreme heat" that is good to upwards of 2000°,,,!!! It must be special order stuff as I've never seen any around here..
shameless dude
Posted: 03 Feb 2020 at 12:19am |
don't Permatex make something like that too?
desertjoe
Posted: 03 Feb 2020 at 1:49am |
I have not ever seen any Permatex product but there sure might be,,,,actually,,,if you needin some patch material for where you need some heat tolerance,,,the JB Weld Extreme heat looks like the best,,,,, HMMmm,,,gonna check out Amazon see what they got,,,,
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 03 Feb 2020 at 9:25am |
All depends on want u are using for.
HD6GTOM
Posted: 03 Feb 2020 at 12:37pm |
Dog gone it, I have never seen anything of these products, except plain old JB Weld. Guess I'll have to ask next time I'm at NAPA.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11413 |
Posted: 03 Feb 2020 at 3:19pm |
I have used PC7 it works and comes in 2 parts and you mix them together, it's solider and used it on sand stone monuments so it takes all kinds of weather. When I used JB Weld it wouldn't take the freezing weather
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 03 Feb 2020 at 4:06pm |
I have used PC7 also. Good stuff Maynard.
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 03 Feb 2020 at 8:20pm |
Sorry to hijack but, chaskaduo, where is the Maynard from? I've heard and said that for as long as I can remember but don't know origin. Oh, and I have used Lab Metal from Fastenal as a filler, not an adhesive.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 03 Feb 2020 at 9:32pm |
Gonna take a stab in the dark and say it's a reference to Maynard G. Krebs from Dobie Gillis.
shameless dude
Posted: 04 Feb 2020 at 8:17am |
yep
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25271 |
Posted: 04 Feb 2020 at 8:39am |
DEVCON make a lot of it ! I know the steel epoxy will seal a gas tank that a hachet made an 'inspection slot' in it.......
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 04 Feb 2020 at 10:32am |
Thank you Jay. I knew there was another brand my local engine machinist guy had me looking all over for 25 years ago. His way or the highway,cause he can work wonders if he wants to help you. But don't ever expect much if don't follow his advice all the way.Don't know if it was worth the effort as it was only a JD put put.
![]() ![]() If Oh Shameless ever comes and visits I can fill him up on Black Label and let him express his anger on the popping johnny. |
chaskaduo
Posted: 04 Feb 2020 at 12:10pm |
I watched Dobie Gillis when I as a kid.
Darrell G (MN)
Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Posted: 04 Feb 2020 at 12:42pm |
I have used Lab Metal, however it must be very clean, they also make a high heat version and I used it to repair an exhaust manifold two years ago and it's still holding
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 04 Feb 2020 at 12:49pm |
I use the permatex/loctite epoxy mixer cups regularly. They come 10 in a can, and are part number 21425. Once in a while I get an old batch, one part or the other is dried out. I've been using this stuff on Roosa pilot tubes for years. It used to be marketed by Caterpillar as well, which is how I learned of it. Cures much faster than traditional JB Weld, and JB Quik wasn't good enough for pilot tubes.
