DD grader hydraulic pump gpm, press? |
Wes (VA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jan 2020 at 7:34pm |
Ive got a grader with no engine, and the center section of the pump is busted. Found a 262 gas to put in, I want to know if parts are availabe for the pump. Its a hydreco 078178. What would be more helpful is the specs of the pump. I see surpluscenter has a couple hydrecos
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3777 |
those pumps are only 12-1500 psi. acccording to the book. not a lot a pressure back then. no specs given on gpm but 10-15 should suffice
Thanks Cal
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 30026 |
Unit on my crawler is 40gpm but still less than 1800psi.
HDg6 is 40 gpm and relief is 1250 psi max
Ages Cat ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 685 |
The pump used on the D is avaialble from Hydreco. I purchased a new one 3 yers ago, about $650.00 complete. I can look at it and provide a part number.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,620, 720, ACP25 lift truck, 1956 D Grader, AC 540 loader, 655 loader, AC #84 plow, Simplicity tractors, Agco MT225. |
Ian Beale ![]() Orange Level ![]() Joined: 03 Oct 2011 Location: New South Wales Points: 943 |
Ages Cat Is Hydreco still in business then?
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Hydreco is still in business.
Part number does not look right. It looks more like a spec no.
