WD45
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 24 Jan 2020 at 3:04pm
I was plowing snow today with the WD45 . It makes a cracking sound in the back rim so is that the eccentrics are worn bad or the rails???thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:07pm
Check the 8 bolts in the center of the wheel first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:35pm
Ok will tomorrow
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 5:38pm
Could be a loose eccentric, too.
WC, CA, D14, WD45
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 5:48pm
if you hear the sound when going from forward to reverse, then it is the eccentrics letting the center move back and forth between the stops in the rail.
If it makes the sound when going at a constant speed in one direction, tighten the 8 bolts holding the center disk to the axle flange.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 6:31pm
Also check to see if the eccentrics are turned to the lock position too. I would doubt that the rails would be worn, unless something is very loose.
Cold weather can test everything!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 11:14am
Ok checked the 8 center bolts they were not loose.It only does it going forward.The eccentrics are tight soI am thinking that they are worn bad enough to cause it to crack sound. Another thing it only does it on a really hard pull. I have never hear it when mold board plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 6:14pm
Yeah, your eccentric blocks are worn after years of use.  I had that happen once to me.  I pfarted around for a week trying different things and in the end, I called Sandy Lake and got some new ones.  They are still solid, no squeaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 7:28pm
When you buy new eccentrics you get both the pin and the other piece that the pin goes into
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 5:44am
I've loosened them up and slid a piece of a hacksaw blade into them to tighten them up.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 8:10am
I did what Paul did but I used band strap it's been 15 plus years and it's still working fine.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
This page was generated in 0.224 seconds.
