D-17 D series II transmission issues |
Post Reply | Page 12> |
SSD17
Bronze Level Joined: 20 Jan 2020 Location: Texas Points: 16 |
Posted: 21 Jan 2020 at 7:04pm |
I bought a d-17 this past weekend from a guy who said transmission was stuck in reverse. When I got it started i found that reverse is forward and the forward gears go in reverse accompanied by a horrendous noise, even when shifter is in neutral and I let out on clutch the noise is heard. He had gone through top shaft years ago and got it back together and it did this so he parked tractor. Is something going on ahead of main trans in power director? I figure I will have to split anyway but didn’t know if anybody has dealt with this before. Thank you
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22811 |
I would think, if he put it back together with the ring gear on the wrong side of the pinion, he may have not done a good job on the transmission work.
My first thought on the noise would be something in the clutch, or the throw out bearing is toast. |
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 610 |
I would say he put the differential in wrong. Sounds like there may all so be a bearing out or gears in the wrong order. The power director shouldn't have anything to do with the direction the gears move you
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Yes, he did install the differential pumpkin in backwards, that will have to be taken out and switched around. As far as the noise goes, you will have to be more specific as to what the noise sounds like and see if you can identify a section that it is coming from. The noise occurring when the clutch is let out and not when you push it in, indicates its not a throwout bearing. Could be in the PTO gears right behind the clutch, in the power director section right in front of the transmission, or in the transmission input shaft/bottom shaft. Report back with more detail on the sound and location. AND WELCOME TO THE FORUM!! Lots of knowledgable guys on here! We will help you fix any troubles with your Allis tractor's!
www.awtractor.com
SSD17
Thanks everyone for the replies! Alex09 It sounds like gear noise to me and seems to be coming from transmission. I have a video I will see if I can cut and upload.
SSD17
is this gear supposed to spin free when clutch is pushed in with tractor off??All other gears on shaft do.
4E09A617-AE75-414D-897C-58FC56BB03A9.jpeg Edited by SSD17 - 21 Jan 2020 at 8:50pm |
rw
Silver Level Joined: 28 Oct 2009 Location: United States Points: 381 |
No
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
Sounds to me like you need to get a good service manual and completely gut the case and start over. One very important issue when you reinstall the ring gear is to make sure the shims are correct. Get the right thickness of shims for proper bearing preload then install pinion and useing a dial indicator move shims from side to side to get correct back lash. If the former "mechanic" got the ring gear on the wrong side of pinion I would assume the shims are all wrong also.
SSD17
I have the IT manual that the seller gave me with tractor, but I would definitely like to find a more detailed service manual. Any suggestions on where to find one?
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5188 |
Sign up for 'GrandpasTractors.com' Many original Allis Service Manuals available on line including D-17. You can 'Copy and Paste' to your HardDrive. Gary https://www.grandpastractor.com/ Edited by Gary - 22 Jan 2020 at 11:12am |
SSD17
The teeth on ring gear face to the right (looking from rear of tractor). The illustration in manual is vague on which direction is front .
SSD17
Orange Level Access Joined: 12 Sep 2009 Points: 19630 |
Will work either way, but that way ain't right for a farm tractor.
SSD17
Thank you DrAllis! I guess I will be pulling finals and swapping it around! I’m beginning to to think there are some missing parts in transmission!
SSD17
The lock nut was loose and I believe I’m missing a thrust washer
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8049 |
Another case of someone doing repairs who had no business doing it. Saved alot on labor?
Someone before me had been in the PD on my 8070 and they sure couldn't do anything right. |
SSD17
You’re exactly right! He said he rebuilt the motor too, so now I’m beginning to doubt he did that right! but it does start right up and sound good.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4435 |
Do yourself a favor and buy an Allis Chalmers Service Manual (Not IT) for your tractor. The AC manual has a lot more (and better) info than an IT manual. You may find one online (like Grandpa's tractors) that you can download. I printed one out, punched holes in it and put it in a looseleaf binder. When I'm working on something, I copy the pages that pertain to it, so I don't get the originals all grease.
SSD17
I must be an idiot because I cannot find a service manual for a d17 on grandpas tractors.
Gary
SS I see what you mean. I had downloaded it back in 2012 - D-14, D-15, D-17 Service Manual. There are some on ebay Gary https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=allis+manual++d-17&_sacat=0 Edited by Gary - 22 Jan 2020 at 9:33pm |
CTuckerNWIL
That is what drives the reverse idler gear when it is shifted into reverse and has to be locked into the top shaft at all times. The 4 other gears have a shifting collar that lock them into the top shaft when shifted into each forward gear. |
CTuckerNWIL
It seems as though Grandpas tractor site has been inactive for a couple years. Too bad, it was a good source for manuals, even if there wasn't a lot of activity on the forums there.
SSD17
Do I need to pull finals before rock shaft? I have the pin out of the ram and all bolts undone maybe it’s just got that much silicone holding it on??
SSD17
It was that much silicone!!!
SSD17
When ordering parts for top shaft it goes by transmission serial number correct??
Never knew there was a tranny s/n. Use the chassis s/n.
SSD17
The main shaft snap ring (#23) was missing. Is there a way to see what thickness I need since there are 5 different options for it?
I think the procedure was to measure end play with feeler gauge to figure out thickness. This assumed you had the old snap ring in place.. Don't have the specs but the least amount of play you can get is what you want. Need a tad but not floppy. A factory manual should say what you need.You may have to find one that fits shaft and measure up from there.
Jim.ME
Orange Level Joined: 19 Nov 2016 Location: Maine Points: 937 |
AGCO Publications is the source for OEM manuals, cost is less than many advertised on eBay.
AGCO Publications |
You want the thickest one that you can tap/pound in with a small hammer and punch.
Edited by DrAllis - 28 Jan 2020 at 5:59pm |
