majic paint |
Kevin210 ![]() Silver Level ![]() Joined: 08 Oct 2018 Location: Indiana Points: 430 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2020 at 5:53pm |
What do guys think about majic paint.I watched a video of it used on a small ford tractor and I have to say it did look pretty good afterwards.
Has any one used this majic paint!!!!! Thoughts!!! |
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 709 |
You're probably going to hear people say it's bad, but if the directs are followed to the T, it works pretty well.
When people don't surface prep, don't use the hardener and ignore the 24 hour recoat times, there are problems.
1951 B
It's definitely better than aerosol cans, however, high quality paint is not cheap. You will get what you pay for.
levipatch ![]() Bronze Level ![]() ![]() Joined: 05 Jan 2019 Location: North carolina Points: 46 |
I have used it a lot. Its tough but fades fairly fast.
Billy..Big cam 300, bcam 400,,941 CAT.,,Deere excavator..900 row crop.. 66 D 17 diesel IV... 985 Pratt and Whitney..4360 Pratt and Whitney... gitten tired !
clarkscreek ![]() Bronze Level Access ![]() Joined: 04 Mar 2017 Location: kentucky Points: 137 |
Adhesion is great and lays down smooth whether brushed or sprayed. However it sun faded pretty fast.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24729 |
Never heard of them but.. from their tractor spray can page... Made with 100% vegetable oil and renewable material, including 100% U.S. grown
soybeans and is non-toxic when dry. |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12225 |
Great! So now, the mice will munch on your wires, then go lick your paint for desert!!
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I did a test a few years ago by applying two different paints to a piece of steel and leaving it outside. Been going for 4 years now. The color was red, and the brands were Majic and Corotile Industries (alkyd enamel as well), both with hardener. The Majic faded to pink within a year but the Corotile paint is still a nice red.
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Big Fader!!!!
The only time my B is outside is when I am using it. That being said, I haven’t had any fade. It can be clear-coated too which would help with durability and fade....but I didn’t do that.
1951 B
OldAC ![]() Bronze Level ![]() Joined: 01 Feb 2018 Location: Rural Michigan Points: 176 |
I've used it. I personally think Valspar or Van Sickle is much better.
My 210 doesn't sit out any and it doesn't get used much either since I use to pull it a lot.I have the motor off right now and am replacing it with a 3700 MK II motor and want to paint it while it's apart.
I'm not a painter by any stretch of the imagination but have some friends that do a lot of painting and can help me. Of course everything looks good right after it's been painted but I haven't seen anything after some time that was painted with majic paint. |
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
I had good luck with Van Sickle but last time I looked for On Line vendor I did not see anything. Orschelin stores have all closed up here, they used to carry it. Never thought my painting skills were good enough for the more expensive stuff.
My tractor stays inside so has not faded much in 10 years or so. I did a trailer and plow and they faded more since they sit out. |
