7000 engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 7000 engines
    Posted: 16 Jan 2020 at 10:10am
Was looking at design differences as in the Stanadyne fed 7000 military engines. WP is moved, front of engine different, no oil coolers, defined a problem that would be difficult at best to transplant. Why is it a Roosa Master style pump could not be modification mounted to replace the PSB AB? Both are distributor based. Fuel lines can be made.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 10:22am
doesnt 1 turn crank speed and the other half speed?  seems i recall hearing this before as ive pondered the same thing.  im sure it can be done just a matter of relative cost
Edited by CAL(KS) - 16 Jan 2020 at 10:23am
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 12:17am
yes afaik thats the problem with the fuel pumps. PSB turns at engine speed. Roosa at half engine speed. Also on the milatary 7000 is no auxially pulley drive for the fan.
But have heard of people putting them into HD6s.
tits tyres and tracks
they all cost you money
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 12:21am
I'm guessing that  the water pump will be in the same place, so why not drive it from the crank pulley like earlier ones did?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 12:57pm
yes thats what they had to do with the repower Ian.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 1:01pm
Thanks.
This page was generated in 0.193 seconds.
