new tractors with DEF |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25308 |
Topic: new tractors with DEFPosted: 11 Jan 2020 at 1:15pm |
anyone own one ? what happens if you run out of DEF and shut it off ?? will it NOT restart until DEF is added ??
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 11 Jan 2020 at 1:39pm |
In my 2016 Duramax, apparently the Power is reduced, and maximum speed is 5 MPH. |
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 11 Jan 2020 at 1:45pm |
I know the trucks will eventually derate the power and will not start till DEF is added if shut off.
cottonpatch
Posted: 11 Jan 2020 at 2:16pm |
On the John Deere side, the tractors will derate. I did have one customer that ran his 5100E out and it would not restart until DEF was added. We did a software update to rectify this but I think he is too gunshy to try and replicate
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
ac fleet
Posted: 11 Jan 2020 at 3:37pm |
They tell me the running out will blow the engine up! The big green farmer across the river blew up a green combine motor by runnin it out! JD said "owner neglect" ---NOT covered!
bigal121892
Posted: 11 Jan 2020 at 3:43pm |
There's got to be more to this story.
Posted: 11 Jan 2020 at 3:44pm |
hmm sounds like some do some don't... man I'd be mighty POed if my 400K combine dies cause the computer didn't shut it down when it KNEW DEF was low ... or... at the far end( always, right) of a 1000AC field and the tractor shuts off due to low DEF. Man , that'd be a long friggin walk to the barn !!
Dnoym N. S. Can.
Posted: 11 Jan 2020 at 4:07pm |
Jay just pee in the tank and take it home LOL B:-) Dnoym
Gary
Posted: 11 Jan 2020 at 4:25pm |
How could 'running out of DEF' blow up a motor. In my Duramax the DEF is added to the Exhaust AFTER it leaves the Engine but before it reaches the Catalytic Converter. |
leoversteeg11
Joined: 15 Dec 2011 Location: OTTAWA ONT Points: 182 |
Posted: 11 Jan 2020 at 5:35pm |
Putting DEF in the fuel tank on the other hand, WILL destroy the engine. Apparently this has been done.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3673 |
Posted: 11 Jan 2020 at 6:24pm |
Agco units use a variable rate of injection - they do not inject until engine load and temp is correct and it is needed. IF the def runs out it just de-rates the hp and rpm. In my experience the Def is much less of an issue - if kept clean- than the regen... burn off -- of the particulate filter. That is a terrible idea and system...
bigal121892
Posted: 11 Jan 2020 at 7:42pm |
This has been my experience as well. If you have tractors that use DEF, then I would think you would be setup to add it when you fill with fuel.
oldways
Posted: 11 Jan 2020 at 8:59pm |
My Bota L47 TLB has the Regen . Only thing I don't like about the tractor.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 12 Jan 2020 at 10:07am |
Don’t know about tractors but we have a 2019 F350 with roughly 3000 miles and still shows 1/2 a tank of DEF. seems like on that truck it just needs filled at each oils change. At that rate I would think it would be hard to run out
ac fleet
Posted: 12 Jan 2020 at 11:19am |
The guys that work for the 70,000 acre big green farmer are not the sharpest knife in the drawer, so who knows which tank they put the stuff in. He has 17 other combines, and never did hear how many tractors, trucks, etc. he has! ---Must be nice to be able to put the little guys out of farming!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3672 |
Posted: 12 Jan 2020 at 11:47am |
I operated a JD S670 combine this last 2019 fall, harvesting corn(830)& soybeans(35’draper). I’m a huge Gleaner combine fan, so nothing against them. Aside from its turret unloading auger & higher fuel usage, the Deere’s capacity impressed me. It’s 15 gallon? DEF tank would usually last about 2 or more diesel fuel tank fills(250 gallons). I think a general DEF Ag usage application is 2-12% of fuel usage?
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 12 Jan 2020 at 2:18pm |
My Duramax and Eco diesel Jeep both give me at least 500 mile warning to add DEF before they will de-rate. Tractors are all pre-emission technology. Local farmer all in a rush with hired help had a worker put DEF in the fuel on a FENDT. New engine on his dime !
bigal121892
Posted: 12 Jan 2020 at 2:46pm |
Now that I can understand.
Steve in NJ
Posted: 13 Jan 2020 at 10:27am |
DEF doesn't blow up engines UNLESS you put it in the main diesel fuel tank! All of my bucket trucks at work run DEF and a couple of our linemen have run out of DEF comin' back into the plant. The computer puts the truck in "limp mode" which equates to about 10-15 mph. In the couple cases that we had, it turned out that the bar gauge was incorrect because the floats were stuck in the DEF tank and the tank ran out or the doser valve that feeds the DEF to the Cat failed. Our guys usually fill the DEF tanks up once a week depending on where and how far away they are working from the plant. During storms they fill em' up every other day while on the 16/8 storm hour shifts...
Steve@B&B
cottonpatch
Posted: 13 Jan 2020 at 2:39pm |
Diesel fuel in the DEF tank will cause some headaches like taking out the DEF pump in the tank and forcing a tank replacement, but have not seen an engine loss at the two JD dealers I have worked at. There has to be more to the story on the guy losing a combine engine by starving it for DEF. Second, I am surprised the dealer and Deere did not subsidize his replacement on a new motor, especially having a fleet of green. We go above and beyond to take care of customers to a fault. It’s what builds loyalty to a dealer/brand IMO.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 15 Jan 2020 at 9:32pm |
DEF in the fuel tank won't destroy the engine, but it does ruin the entire fuel system beyond the fuel filter. I've gotten in on fixing them after that issue. It takes about 40 hours to replace all of the high pressure fuel system on an F250. I also did a fuel system on an LGH Duramax ambulance. Not fun at all. Running the system out of DEF doesn't result in a no start, but it will go to idle only.
I will sort of walk that destroy the engine back just a bit. I haven't seen it personally, but the 6.7 Powerstroke uses a pressed on cam gear with no key ways. If the injection pump seizes it can spin the crank gear. Since there's no way to put it back in time, your options are a short block.
