TSC LARIN drill press vice |
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2622 |
Posted: 08 Jan 2020 at 2:34pm |
Anyone know if these are any better than whatever harbor freight ? Thanks
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5212 |
Link to TSC Drill Press Vise $29 https://www.tractorsupply.com/tsc/search/drill%20press%20vise Harbor Freight $18 https://www.harborfreight.com/4-inch-jaw-capacity-drill-press-vise-30999.html |
ACinSC
Thanks Gary .
shameless dude
I have one from HF, has worked for me for prolly 10 years. it's not has heavy in weight as others, but has done the job o-k.
ACinSC
Thanks Dale .
Dave H
Orange Level Joined: 11 Sep 2009 Location: Central IL Points: 3485 |
I got the HF one. The quality leaves something to be desired, however I am a casual user and it serves its purpose for me.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21725 |
I've got 3 or 4 of the them ( have 2 drill presses), NONE are beside the drillpress I use, hmmmmmmm) The big deal is to put thread locker on the screws securing the movable jaw ! Tighten just enough for a smoooooooth fit. From the factory, they're too loose.
ACinSC
Yeah I don't need one very often so a cheap one should do . Gotta be better than nothing . Thanks
chaskaduo
Spend the other 11 bucks on there cheap drill bits.
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13376 |
Yeah I don't need one very often so a cheap one should do . Yeah,,AC,,you answered the main point,,,, It all depends on how often a guy uses the tool,,,,AND,,,how close you want your work to be. I've got 2 HF ones and have always been satisfied with their performance,,,,, Say,,,maybe the Guru's here can help me ID an older vise I picked up at a yard sale ,,,It is 6# wide and 12" long with a removable handle. Only'ist numbers on it are " #3 " The end of the screw is square where the handle goes. The moving jaw has adjustable plates underneath for really close work. That sob weighs at least 50#,,,,,?? Anybody recognize it,,?
ACinSC
Sure could've used one when I drilled a 1/8" hole in the D 15 top link adj rod to put in a roll pin . Now when I need it I can find it . Need to just get a cheap one so I'll be ready next time . Thanks guys
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2598 |
I have found that there is more wobble in my cheap drill press spindle than in jaws of my cheap vice. I do have a very good drill press with a very good vice for the stuff that requires it.
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6164 |
I would think the quality of the HF vise is as good or better that the one from TSC. IMHO the prices at TSC seem to exceed the quality of their products, especially their tools.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41274 |
Probably madein same facory by same chines machinest .
Have a couple cheap ones by drill press but when it's got to be right - use the vertical mill and Bridgeport vice clamped to the ways on the mill |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78584 |
YEP... Hong Jong FU makes TCS on M-T-W... then HF vises on TH-F-S !!!
ACinSC
Yeah those vices look pretty similar to me . Thanks
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2259 |
I have a cross slide and a regular one from HF, and yes they are loose but do hold really good. I have drilled some nasty stuff that was being held in them. Also use them as a welding vise since welder is close by. I think they are worth the price. IF ya gotta have +- .0001 --- No good, but for our use they suffice !
ACinSC
Thanks(1)
Thanks Sonny . Kinda what I'm thinking .
