210 injection pump removal
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Topic: 210 injection pump removal
    Posted: 05 Jan 2020 at 1:28pm
Guys its been about 20 years since I last pulled the injection pump off our 210. I cannot remember if I needed to remove the oil cooler. I was thinking I was able to wiggle it off there without removing the cooler. The old IT manual says it needs to come off, but I know they are not always accurate. thanks for any info
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 1:55pm
I pull the shaft and gear forward out the access opening. I don't take lines off or oil cooler. Just disconnect lines at pump. Just be sure to bring up the marks inside the pump first, will make installing a little easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:20pm
thanks Ed...it worked just as you described !! pump will be heading your way sometime this week!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 7:11am
good deal. Going back on is a little tricky, I slide both cup seals about half way on(proper direction for each of course) to get the pump into position still allowing the shaft to be half out the front. Once you get pump into place, but held back for access, slide shaft in some, then work seals forward, little by little until they are in their respective groove. Also, don't forget the little thin o-ring on end of shaft splines, it can be put on before starting all this. All these seals are provided when I do the pump rebuild, as well as the front access cover gasket.
PDehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 11:12am
I'm working on removing a 220 injection pump.  The front access cover needs to come off and then the gear and shaft can be pulled forward as an assembly without any further disassembly correct?
About how far forward does the gear and shaft have to slide?
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 8:52am
as far as it'll go. I reach in and break the cup seals off so the shaft will slide into the adapter bushing.
