U joint grease fittings |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Dec 2019 at 5:49pm |
NOT 1/8th or 1/4 NPT. Somewhere in between . Need 2 to be able to keep my Brush Hog Drive Shaft U joints Greased. Replaced yoke using same old cross and cups. Old yoke was not for a 1 3/8" 6 spline gearbox output shaft. Noted the grease fittings were both missing. TSC had what I needed. Broke the Bank to take the right yoke home.
I thought I had a good selection of Grease Fittings until nothing I have threads into these old crosses . Is there such a thing as a 3/16 Grease Fitting?
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
Could they be metric ?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54331 |
Drill them out, to the next biggest size you have, and tap them to that size...
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88331 |
the smaller one is a 1/4 inch bolt thread... the larger one is 1/8 inch pipe... never seen one in between.
might be the "push in" type. found that on a new mower I have, one dropped out and the hole wasn't threaded, and the dealer told me they were the push/pound in type. I got some and ruined one when I pounded it in. found a really small metal tube and pounded on that after placing the zerk up inside it.
You got it Backwards Steve The small zerks in my assortment are 1/8 NPT the bigger are 1/4 NPT. Went online and found 3/16 grease zerks . All shapes , straight , 45 and 90s . Problem is 3/16 WHAT?
You got it Backwards Steve The small zerks in my assortment are 1/8 NPT the bigger are 1/4 NPT. Went online and found 3/16 grease zerks . All shapes , straight , 45 and 90s . Problem is 3/16 WHAT? All I know is a 1/8 is to small and a 1/4 is to big
He might have mis read. Size wise, 1/4" x28 tpi bolt thread are the smallest. Check hole with a 7/32 drill bit. If hole is bigger, use a 21/64 drill bit and check if that's it, then its a 1/8 pipe thread... Never heard of a 3/16 bolt or pipe thread.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4758 |
They do make metric.You got it at TSC ?
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24756 |
oods are real good they are METRIC ! I've got some 7/8" bore pillowblocks here.....Zerks ARE metric.... I assume the default nowadays is Metric. then 'soft' conversion, then Imperial. Soft means stuff that goes bothways....like 5/16<>8mm Jay
3/16 zerk is smaller than the 1/4 inch bolt thread size... You drill a 3/16 hole and POUND it in.. not threads, just TEETH.
there are a variety of zerk threads.. the two most STANDARD are the 1/4 inch bolt thread and the 1/8 inch pipe... you can also find 1/4 inch pipe and other, but not that common.
a 1/4 inch BOLT thread is .250 inch diameter - an 1/8 inch pipe is .400 inch diametera 1/4 inch pipe is .540 inch diameter a 12 mm ( metric) zerk is .470 inch diameter. ( or about half way between the two pipes).
Edited by steve(ill) - 08 Dec 2019 at 8:55pm |
