82T sickle sections
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: 82T sickle sections
    Posted: 03 Dec 2019 at 12:25pm
I just recently bought a 82T sickle mower...I would like to put all new sections on it so they all match new and would like to put overserrated sections on it.  I see a lot of people suggesting the underserrated sections...just wondering what the advantages of these are compared to smooth and overserrated.  I would also like to go with bolted sections instead of rivets.  Can anybody suggest part numbers of sections and bolts that have worked for you in the past?  Thanks in advance.
Matt Folkers
FOLKERS RESTORATION
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 12:58pm
SCH sickle parts fit on allis mowers and haybines. My cousin bought parts at AGCO and bolted the drive heads on and has been mowing ever since
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 1:22pm
I bought all of mine from our local Farm and Home store. I have seen them at TSC stores too. Herschal MFG in Indianola Iowa makes them. Be sure to get the Chromed sections. They are a lot tougher than the black mild steel sections. Mine are top serrated. You will needle taller hold down clips for the sickle in order to clear the bolts. I converted mine to bolt ons.   It iscthe only way to go
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 2:50pm
Make sure you put the nut and bolt in the correct direction.  I did an entire No. 3 bar before I discovered that I had put them in wrong.   They are a bugger getting back apart.  I am glad I was taught how to take the rivets out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 3:57pm
Webb's Sickle service. But the whole blade and knife head. Great folks and great product! Tracy
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 6:38am
I 2nd Webb's and  I still use the rivets think they hold the sections tighter and i use bolts to replace a broken out section but put the nut on from underneath.Do not like the
tall hold downs as they will make it easier to clog up in short hay.
