Gasket adhesive
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Gasket adhesive
    Posted: 25 Nov 2019 at 2:44pm
I used Indian Head shellac when I put the hydraulic oil pan on the D 15 . It didn't hold the gasket as well as I'd hoped . Maybe because it's old, I dunno . Just wondered what you fellas use ? Thanks
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 2:52pm
brush on high tack [permatex brand] if i need glue one on a part before asssembly real sticky and sets fast,
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 2:56pm
CNH makes a gasket glue that works amazingly well.
I can't remember the name of it but the Case mechanics call it "calf snot"
A little CQB never hurt anybody.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 3:00pm
was the surface clean?
HD3
200 10and20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 10and20 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 3:08pm
Get the best Copper Coat. Costs more but it's more than worth it. Make sure surface is clean and free of oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 3:12pm
Yeah I'd cleaned the pan well and even wiped it off with alcohol . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 5:49pm
lay the pan on a piece of plywood, mark and drill all holes. then place gasket on plywood, and smear the top surface with blue goo. (blue silicone) Go lightly with the blue goo, you really don't want any squeeze out...  place pan on top, and put all bolts through holes, to align.  If you have longer bolts, to go through the pan and plywood, use them, and tighten them down till everything is flat.  You really don't want to over torque these.  If you don't have longer bolts, clamp the pan to the board, or weight down the pan.  This way the gasket stays with the pan, to make assembly easier...Wink
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 5:50pm
Permeated aviation gasket cement
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 7:03pm
Thanks guys !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 7:10pm
Copper Coats one of the least desirable,, Hi Tack is the good stuff,,
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:20pm
I always Use Indian Head and have had zero problems when the directions are followed. You can't hardly get it back apart after it has set up.
As a side note they now call it "lion". I guess "Indian Head" was too politically incorrect.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:57pm
Hi Tack is the best. Copper Coat works better for antiseze than it does for gasket sealer.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:13pm
An fashion way to keep gasket in place with pan is to use string and tie the gasket in several places.   When bolting it up place bolts and start them into block.  Once you have several bolts in place cut string and pull out one at a time as start bolt in the string hole.  This is an old mechanic trick from the 50's and 60's   This is with an in frame  overhaul.
Edited by festus51 - 25 Nov 2019 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 10and20 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 4:26am
Copper Coat makes the best headgasket sealer. Copper Coat also makes antiseize. Same brand 2 different products. Like Hi tack it is also made by permatex.
Edited by 200 10and20 - 26 Nov 2019 at 4:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 4:37am
What many refer to as Calf Snot we also called Gorilla Snot in the truck industry, was a contact adhesive slight yellowish in color applied to both the gasket and the part to attach to. We used it on oil pan gaskets on the large engines to get them to Stay where we put them, almost took a grinder or sanding discs to get back off after a few months.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 10:08pm
I use Indian Head myself. Never have a problem unless it's really old. Gotta let it tack up a little before install. Lion is a different brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 9:59am
Yeah Lee , I think my Indian Head was just too old . I threw it away . I'll get a new bottle for next time . Thanks for all the replies .
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 9:28am
   3M weather strip and gasket adhesive, love it.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 10:40am
permatex aviation ,,,,,never had a leak ,,,but its a pain to get off if you have to,,,,but it will take that over leaks,,,any day
ocharry
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 7:08pm
     Yes ! That is yellow stuff we used in the mid 70's. Personally, I would NEVER use.the blue silicon. Use the Clear. If it squishes out anywhere, it is hardly noticeable. If the blue squishes out it draws attention to the repair and looks like crap. Just personal preference.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 11:03am
3M weather strip and gasket adhesive is what I use.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 5:51pm
3m weatherstrip adhesive for oil pan gaskets
and aluminum paint for the head gasket!
This page was generated in 0.385 seconds.
