D19 high low
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: D19 high low
    Posted: 20 Oct 2019 at 1:38pm
Dr Allis you spoke of changing the high side of the hand clutch ratio to get a better ratio between high low is it done by using high side out put gear from a 17 or is there more to it thanks
Edited by bradley6874 - 20 Oct 2019 at 1:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 4:09pm
A 180-185-190-190XT-200 have a 20% drop in speed when in LOW range. HIGH range is always direct drive on all models. A D-17 is a 30% drop. A D-19 is 35% or more. Using the two gears in the front of the intermediate gearset (directly underneath the fuel tank) are the ones that need to be changed to get that close ratio percentage. When using these 20% drop gears, low third is actually faster than high second. The 20% is very close to that of a 1066-1466 Farmall TA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 8:07pm
Ok ty I have a 180 parts tractor the d19 gets a big cubic 301 gas
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 8:29pm
You still making the mechanical HiLow for the 180-190? Or have prints I can have made?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 9:56pm
Still make them when someone desires one to be built. Seems like one or two a year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 6:03am
What do you need for one of them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 6:08am
It all depends on how many pieces you can provide and how many I have to find out of a salvage yard to be able to complete the project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:33pm
Do you haves required parts list to do the Manuel shift box in a early 190xt currently iam coupled direct high but could use 7 th gear some places
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 1:21pm
I sent email to you doc
This page was generated in 0.266 seconds.
