Power window trouble UPDATE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: Power window trouble UPDATE
    Posted: 19 Oct 2019 at 4:27pm
'99 F150 passenger door window went down but won't come back up, figured it was the motor so I replaced it along with the switch I broke while taking it apart still has the same problem. Bench checked the old motor (should have done that first) and it runs in both directions. I will get a fresh start on it Monday, I'm thinking broken wire some where in the door. Any suggestions or helpful hints would be appreciated.
Edited by Hubert (Ga)engine7 - 29 Oct 2019 at 4:15pm
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 4:36pm
If it's like older GM products. motor gets it's ground from mounting on door. Try connecting good ground to motor and see if that fixes it. Otherwise, your probably correct.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 4:36pm
Look in the door jam right where it bends.
Will be the thicker wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 5:17pm
Proabably same as my 97, so NOT grounded inside the dor, it's a 'floating' power system.
Since you've replaced both motor and switch, it's not internal door wiring, or the cable going from right door to driver's side.
I suspect the driver's switch, that ALSO controls the passenger window. If it won't go down...check the tan/lt blu wire. won't go up, wht/yel wire.
You can use Google  to get a copy of the '99 ford f150 power window system wiring.
hope this helps
Jay
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 5:41pm
on the driver door
that where i find brake in the wire
you can try gigging there wile you work the
switch
hope this help
        B:-)       Dnoym
Edited by Dnoym N. S. Can. - 19 Oct 2019 at 5:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 5:47am
hopefully this is the  wiring....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 2:15am
junk it! (poke,poke)
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 7:07am
I had a Chevrolet car that the drivers set of switches had one bad, and one rear window would not operate.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 10:54am
Swap the switches and see if the problem changes to the other window.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 8:44pm
Thanks for all the insight. I didn't get a chance to do much trouble shooting today but I think the problem may lie in the drivers side switch. I did put power to the motor to run the window lift back up so I could reconnect the glass and then run the glass all the way back up.
Jay, thanks for the wiring diagram, I will use it tomorrow.
Fixer, I hope it is not a broken wire. I hate tearing wire bundles apart and splicing wires!
Stan, unfortunately the switches will not interchange.
Shameless, if I junk in my punishment might be having to drive a Chebby.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 10:51am
my 92 ferd, the motors run, but neither window comes down, nor goes up.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 11:27am
Speaking from experience, if you don’t like electric winder problems stay away from Chebby. I’ve fought them on my last two trucks.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:45pm
The only vehicle I've owned with electric windows was a 67 Olds 98 tank with a 425 rocket in it. Oh and the stereo had reverb. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:45pm
Now now Thad. I see lots of late model vehicles while in the drive through lines who have to open their doors because they can't get the window to work. Maybe they are using cheap switches from China now because my Chevy in 25 years has never had a problem with the automatic windows.😉🇺🇸
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 5:30pm
My 96 Caravan drivers window only cranks down to 1/3 open, then it's a hard stop. It has that new fangled X crossed cabled all in one system. Looks like a real stand on your head, eyes crossed, and biting your tongue to replace procedure. Cry  I think I'll wait till it gets worse. Dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2019 at 11:45am
JC, if the motors are running but the window not moving the gears are likely stripped out on the motors or the motors are loose and the gear is not contracting the window crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2019 at 4:19pm
Thanks again for all the input. Turned out to be a bad switch on the driver's side. Ordered a Standard Motor Products switch from Rock Auto since they were $$ less expensive than NAPA even with shipping.
This page was generated in 0.139 seconds.
