ID A Plow |
Armand(AZ)
Orange Level Access Joined: 11 Sep 2009 Location: Mesa, AZ Points: 858 |
Posted: 23 Sep 2010 at 11:25pm |
Can someone tell me the model of this plow?? I thought it is a 2000 but the manual I have of the 2000 shows it without a front wheel. Tks, Armand |
Skyhighballoon(MO)
Orange Level Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Armand - Per Norm's book, the 2000 series monoframe was a semi-mount in-furrow plow. At the same time Allis made a 3000 series monframe that was a semi-mount on-land plow. Allis later came out with a 2nd phase of the 2000 series that had higher frame/trash clearance and Allis dropped the 3000 series but then came out with a 2500 series semi-mount on-land or in-furrow plow similar to the 3000.
I don't know enough to tell from that pic if it's a 3000 or a 2500 on-land plow. Hopefully someone can point out the difference. My best guess in comparing that pic to the ones in Norm's book is that it is a 3000 looking at the linkage on the front furrow wheel. Mike |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
TedBuiskerN.IL.
Orange Level Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
WOW, wouldn't you like to see that rig in action!!!
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Ted, the bad part about a rig like that is the plowing would be done too fast.
Armand(AZ)
Thanks for the info Mike!! I have a model of the 220 FWA built and in the paint booth and started the plow model a couple days ago. Then realized that the manual wasn't showing the front wheel assy. I have the hitch assy and frame built so I guess I will need to decide if it is going to be an in-ferrow or on-land unit depending how it lines up with the tractor. :>) There's a few pictures of the 220 on my website at acmodelsofarizona.weebly.com Armand
Kevin in WA
Orange Level Access Joined: 08 Feb 2010 Location: Lynden, WA Points: 611 |
That is a 3000 series, 2500 series had more clearance.
JimWenigOH
Orange Level Joined: 12 Sep 2009 Location: NC Ohio Points: 1161 |
That is a 3000 Series Semi-Mounted plow. With the proper hitch set-up the tractor could run on land, or in the furrow. The 3000 Series was available with 6 to 8, 16 inch bottoms. The 2500 Series was a Pull Type, and had 5 thru 8, 18 inch bottoms. This info came from my A-C plow Operator's Manuals.
