720 with loader
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: 720 with loader
    Posted: 13 Oct 2019 at 9:52am
I have a 720 with loader. Twice now the steering wheel slips on the steering shaft. I'm beginning to think it should have power steering. Anyone have power steering on their 720? Was it available on the 720 ?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 7:49pm
Power steering was not an option. When I have my snowthrower on I never turn the wheel unless I am moving for that very reason. It weighs around 350 lbs. Do a search for 720 power steering, it seams like someone on here has done one. If I remember correctly some sheet metal in the hood had to be removed.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 2:24pm
There was a one put on from a Chevy Nova I believe. Go to SimplicitytrACtor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 4:43pm
Mike Noonan who is a regular on here and knows a lot about the 720's has a friend of his by the name of Steve Brown. I believe Steve came up with a pretty slick power steering setup for the 616-720 machines.  From what I understand he's done quite a few changeovers and the systems work great. I have a number here, that I'm not sure if its still good yet, but maybe Mike will see your post and direct you to where you have to go.
Here's the number I have for Steve Brown- 608-513-7763  HTH
Steve@B&B
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 3:41am
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 10:39am
Thanks Steve,
The 2 best ways to ad power steering I think is to use a GM 605 unit. It will need modifications to the tractor but seems to work great. The second type would be to use an orbital valve and remote cylinder from a JD 318 or Simplicity Sunstar type tractor. I have used a Vega power steering unit but am not satisfied with it when loader bucket has a full load. There are no doubt other options as well.
Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 4:25pm
Thanks Guys, If I have any more problems I'll see about adding this.
Dusty
This page was generated in 0.418 seconds.
