WD hydraulic pressure
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulic pressure
    Posted: 15 Sep 2019 at 10:01pm
I tapped into the hold valve with a gauge. I used the front port on the clutch pedal side.
The gauge shoots up to 2800-3000 psi when the lift arms top out. Then with the valve handle still in the full up position, the gauge drifts down to about 1800 psi after 10-20 seconds. Is this correct? Or is it a problem?
This WD won't lift much on the rear is the reason I even checked it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 7:16am
Should be around 3600, otherwise normal.        MACK
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 7:52am
Hi
Interesting, do you an idea what pressure it is for an ED40?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2019 at 5:21pm
A .010 shim on the unloader spool will bring it right back to original if everything else is right.  My 45 is running about the same as yours. I left it, because I was too lazy to take the pump off for the 3rd time to get it back to 3500PSI.
