B Hubs
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: B Hubs
    Posted: 21 Sep 2010 at 10:36am
Are all B hubs the same?
Mine are 5 bolt but need to make sure they didn't change something along the line.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 11:40am
All 5 bolt hubs might be the same, I don't have part numbers to confirm that. All B hubs are not the same. I'm not sure what the 37 had but, in 38 the hub was part of the wheel casting and a rim was bolted to the wheel. In 39 there was a 6 hole hub with the rim riveted to the hub. This probably doesn't answer your question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 12:05pm
I'm looking at a set of 5 bolts but since I can't physically put them in my hands I was just checking to see of they are the same.
Charlie
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 2:31pm
My 52 B has 5 holes and an earlier 49 B has 5 holes.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:56pm
All B-C-CA 5 bolt hubs will interchange. Bs after B-26524 were 5 bolt style hubs. I have noticed some 5 bolt hubs having subtle external casting differences.
   Some of the early 5 bolt B hubs had grease fittings. Maybe it was only those used on the early IBs. ???
