carburetor
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: carburetor
    Posted: 02 Sep 2019 at 6:28pm
  Had the Zenith dual fuel carburetor rebuilt on my 1937 WC tractor still will not start with the rebuilt  Zenith, put a good M S TSX  on from my WD and tractor starts rite up. What could the problem be with the Zenith model 7078?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 7:18pm
Have you verified that fuel reaches proper float level?
Rick(NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick(NC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 7:30pm
Does it flood after turning the crank several times? I had problems with mine when I first got it until I learned the combination of - full choke, crank - no choke, crank - and then it will fire if it is timed right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 7:39pm
AC,
 My suggestion would be to go back through the Z carb again. I had a WD carb I kept opening and switching parts and checking things till I got the right combo. Good luck, and good that you found that it was the carb.
FYI I like the Marvel carbs for some reason. I have not rebuilt a Zenith carb, but the D17 has one.
Nice work.
Edited by Sugarmaker - 02 Sep 2019 at 7:40pm
