C vs. CA |
![]() ![]() ![]() ![]() ![]() Posted: 30 Aug 2019 at 7:59pm |
I was reading the newest Antique Power this morning and saw this ill informed opinion printed. Seems there should be a delete button for Facts that aren't facts when they are printed.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88293 |
why would Antique Power publish something like that without Checking first ?? ......... and you wonder where some idiots get their info.
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2670 |
Evidently opinion overrules facts anymore.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
![]() I do wonder what the "A" in CA really designates.
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I saw that letter yesterday. Was thinking someone should write a letter back. I have a CA just like the one in the picture. Other then the 4 speed and 2d clutch, what differences are there between a C and CA? Creston, the A stands for AWESOME! Edited by JohnCO - 30 Aug 2019 at 9:54pm |
Allis Express participant |
Haha, good one, John!
CA also has power shift rear wheels.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3931 |
Just send Rick an e-mail pointing out the correct info.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Snap coupler available on CA too.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
My CA had a TB guage on the steering column.. it was a '51 I think, had it been a '53 it'd still be here.
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
So if I had an adjustable width front end on my B it would be considered a BA, and if I put duallys on the rear also then it's considered a BAD tractor. That's BS or dare I say it "Fake News".
I sent a message right away on facebook and got a reply that the editor would be notified.
The differences that i can think of are, the tapped bosses in the front pedestal , tapped bosses on the torque tube, Platform under the drivers pan seat, 4 piston(WD) hydraulic pump with Traction boost,(not all CA's had the Snap Couple or TB gauge), magneto only the first couple years of production, power shift rear wheels with different bolt pattern than the C, higher RPM, option of a hand clutch on one rear axle, and what am I forgetting? |
Four forward gears.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
The fellow might have see a CA with a narrow front from a C. No difference other than the above stated cultivator bosses. I put a CA narrow front on my C I pulled with to use the bosses to mount weight out front. Think about all the C's that confuse people that have B wide fronts. Not everyone reads these boards as we all do.
The shop manual that covers G, B, C, and CA will show some factory differences:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 709 |
‘Course there’s the fact that the CA replaced the C and they were never manufactured at the same time....that little detail.
1951 B
the final drives on a B and C are bolted on straight up and down with respect to the bolt pattern......... Seems like the CA they are tilted back slightly to give it a longer wheel base ? Or did I dream that ? Have not seen a CA for several years.
The bolt pattern is the same for all three. The final drive casting is what sets the rear axles back. |
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1568 |
I used to have a CA single front. Would that be a CS? Edited by Jordan(OH) - 02 Sep 2019 at 12:50am |
WF, NF, single wheel. They were all called a CA. Unlike another tractor manufacturer, AC didn't nit pik names for the same tractor with slightly different options.
Dale (Stonelick) ![]() Bronze Level ![]() ![]() Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 185 |
I read that there were 10 improvements in model CA over model C: 1-increased HP, 2- improved hydraulics, 3-four speed transmission, 4-heavier axle, 5-draft control, 6-seat shocks, 7-improved hitch, 8-hand clutch, 9-live PTO, 10-spin out wheels.
So that would mean you have a CAHPIH4SPHADCSSIHHCLPTOSOW, now put that on the tranny before the serial number.
