engine rear seal |
pinball
Joined: 28 May 2014 Location: missouriu Points: 6424 |
Topic: engine rear sealPosted: 29 Aug 2019 at 6:03am |
have anyone tried something to slow down a leak on the rear seal of an allis engine. thanks
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8576 |
Posted: 29 Aug 2019 at 7:25am |
Remove engine and crank and reseal is one option. But usually other things happen when your in there! I know this wasn't what you wanted to hear. Not sure of any quick fixes? The experts will be along soon.
Regards, Chris
MACK
Posted: 29 Aug 2019 at 7:39am |
What engine? MACK
pinball
Posted: 29 Aug 2019 at 9:14am |
d-17
Jim.ME
Posted: 29 Aug 2019 at 9:19am |
How about a bit more about the engine, is it gas or diesel? Which series D17?
pinball
Posted: 29 Aug 2019 at 3:13pm |
series one. gas. thanks
DougG
Posted: 29 Aug 2019 at 6:55pm |
If it has a rubber seal , Lucas makes good stuff, also brake fluid will make rubber seals swell,, just depends on your choice to get by or a tear down
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 29 Aug 2019 at 8:50pm |
Take it apart and replace it. Anything else is just a temporary band aid.
MACK
Posted: 29 Aug 2019 at 9:13pm |
Don't cut ends of seals off. Glue seals in their grooves. Use the F gaskets that comes with pan gasket. Be sure bearings have proper clearance. Oil the seals before installing crank and main caps. Put some sealant on top aluminum seal retainer before bolting it to block. MACK
Adam Stratton
Posted: 29 Aug 2019 at 9:25pm |
My folks had a dodge dakota that decided to start leaking badly all of a sudden. As a desperation move, they used Blue Devil rear main sealer. Got it at an auto parts store locally, dumped it in and never had any more trouble with it. Could have been a fluke, but might be worth a shot?
