1950 b |
Hunt4Allis
Topic: 1950 bPosted: 15 Aug 2019 at 4:56am |
Just noticed that my dad's b has what looks like louvers in front of radiator ( between radiator and front grill, but no way to operate them?
What are they used for? My 53 CA doesn't have these, nor does my d-17??? |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 15 Aug 2019 at 5:45am |
To manually control engine temperature!
Larry in NC
Posted: 15 Aug 2019 at 6:07am |
On your tractor there should be a hole in the top right side of the grill that originally had a crank handle to open and close the shutters.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 15 Aug 2019 at 6:36am |
The earlier tractors did not have a thermostat, so they had manual shutters in front of the radiator, that you could open or close to control engine coolant temperature. There was a crank at the top right side (if you were sitting in the seat) of the radiator shell.
Newer tractors had a thermostat that controlled temperature, so there was no need for shutters.
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2684 |
Posted: 15 Aug 2019 at 7:02am |
Hunt4Allis
Posted: 15 Aug 2019 at 9:14am |
Yep, my crank is gone
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3952 |
Posted: 15 Aug 2019 at 4:20pm |
Replacements are available from some of the suppliers on this forum.
Dick L
Posted: 15 Aug 2019 at 5:59pm |
It was also a way of thinking back even in the late 30's regardless if they had thermostats or not. When Dad started any of out Olivers in 40's he put a feed bag over the front until they warmed up. They all had thermostats. Years later he didn't. |
CTuckerNWIL
Posted: 16 Aug 2019 at 9:05am |
My 51 CA has a thermostat and shutters. It also has a distributor on a mag flange mount that was put on by the dealer before Dad bought it.
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 714 |
Posted: 16 Aug 2019 at 9:09am |
My '51 B has no shutters- doesn't look like it ever did.
1951 B
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8625 |
Posted: 16 Aug 2019 at 8:44pm |
Hunt, I have a handle from a WD tractor that you can have if you want? PM me if interested? I have to find it in the vast waerhouse! ![]() Regards, Chris
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 17 Aug 2019 at 7:34am |
Crank is longer on B,C and CA
Hunt4Allis
Posted: 17 Aug 2019 at 7:44am |
PM sent sugarmaker
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 17 Aug 2019 at 8:00am |
Tony Carbaugh sells brand new cranks if interested. Give Tony a call.... Steve@B&B
Gerald J.
Posted: 18 Aug 2019 at 11:43am |
The shop manual might discuss the shutters and thermostat alternatives:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
