D17 lift capacity
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Topic: D17 lift capacity
    Posted: 11 Aug 2019 at 8:37am
I'm trying to find the 3 point arm lift capacity of the D17. I am looking at no till drills that weigh around 2500lbs. Any help would be appreciated.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 9:32am
Couldn't find any info on tractordata.com. That seems like a lot to me for a D-17. If you post this in the Farm equipment forum you will get a lot more views and replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 10:18am
It will have to be a series 4 for sure. Any add-on 3 pt hitch won't have the lifting power of a properly functioning S4.  If it will pick up 2500 lbs, you will need a lot of front end weights and a wide front axle will help too.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 2:57pm
I made the 3-point kit for my Series 1, and up close to the tractor, it'll certainly lift 2500, but in order to prevent it from kicking out the limiting valve at any reach, I have to idle it down... and be gentle with the controls, and it installs several inches of air between the front tires and the ground.  Probably not functionally practical in the field to run an implement weighing over 1500lbs or so.
You probably won't find any 'three point' ratings for D17's prior to S4, because it wasn't a factory unit.  The factory hitching system probably didn't include a lift rating, because the implement's weight was only a small part of the formula... the load-center distance and reaction loads were equally as critical to effective and safe operation.
