200 drawbar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 drawbar
    Posted: 27 Jul 2019 at 8:53am
Hi.
the drawbar is to low and I thought on here you guys have said to put drawbar on top of crossbar. Does anybody have pictures of it like that. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 9:39pm
I don’t have a picture of mine like that because I only put it on top if I enter a tractor pull. Very simple, remove the bolts that hold the slide plate down(the drawbar slides on it). Slide the roller assembly off the slide plate and flip it up side down, slide it over the drawbar and reassemble with the drawbar on top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:22pm
Ok thanks, will give it a try
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:51pm
Get a drawbar from a 180 or 185, they will set flat on top of the 200s bail. If you try putting the 200 drawbar on top of the bail it puts it in a bind and only rests on the front side of your bail
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2019 at 11:48am
I noticed that on mine when I tried to put it on top. Thanks I didn't know that about the 180 or 185 drawbar.
This page was generated in 0.093 seconds.
