Space saver spare wheel
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: Space saver spare wheel
    Posted: 01 Aug 2019 at 7:21am
I modified a space saver wheel off a honda car it has the same hole pattern as the ca , I just bored the centre hole out a bit and moved the centre of the rim in a bit and re welded it , they are a cheap way of replacing rust rims and the tyres work well
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:23am
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:51am
Since you cut the centers loose, could you just cut the center out of your old rim and welded it into the doughnut rim and have a similar look of original rim?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 8:01am
There is some wheel like that one that will fit with no modification except cut the center
just a little,have a D10 with them on it bought it that way.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:26am
my centres  were damaged and there are not many Allis tractors around here anymore , the wheel weights fit in as well
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 9:29am
There should be a bunch of those in the junkyards. I can't imagine very many people chasing after a space saver wheel.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 4:26pm
Just remember to not go over 50 with it.😜
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 5:16pm
  LOL
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 5:22pm
I put Two of them on Dads "B". Then I bought tires and rims at the GOTO in indiana a few years ago but he likes these :) maybe someday we will get the correct ones bolted on :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 5:40pm
Sure hope the tire was offa the rim, when you welded on it, if not, there may be a big BOOM, in medical bills...Wink
[TUBE]HiLeji8bLOk[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 6:41pm
I 'think' full size Chevy wagon rims will bolt right on, maybe 'old' GMC pickups ? 5 x 4.75 pattern ??
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:01pm
I have a B here that I put space savers on, no mod what so ever, not sure now, but I think they were GM
I am still confident of this;
Wait for the Lord;
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:10pm
Keep an eye on the lug nuts. Those rims should have a metric bolt pattern.
Rog NCWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog NCWI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 7:37pm
I just bought new rim blanks and riveted them on the old wheel centers to make it look like the  original ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 8:01pm
he is from Australia.......... availability and not-common between USA and Australia might be part of the problem.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 8:11pm
 Say,,,!!  That right there is a great idea when the originals are not available,,,Clap Good Job, Steve from down under......
 I'm gonna look into this as I am gettin a Massey TO20 rebuilt and I just DO NOT, NOT like them big old skinny tires and wheels they come out with,,, Thanks for the idea,,,cause I gots a torch and a mig welder and ain't scairt to use emClap,,LOL
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 10:17pm
I put a set of them on a Farmall A.  Used the rims that were on there.  Never had a problem so I guess they fit the narrower rim.  Sure made it better cutting grass.
