roto baler belt replacement
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: roto baler belt replacement
    Posted: 30 Jul 2019 at 7:22am
Will belting cut to length with lace style connectors work when replacing belts on roto baler (take the pressure as bales develop)? If not, I see having to totally disassemble the left side to put continuous belts on - ugh! Thanks for any response or ideas
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 7:33am
Yes, as a kid I remember dad replacing with laced belts purchased at local Allis dealer.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 8:16am
better question is where to get continuous belts?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 8:49am
I have ran laced belts on mine for about four years now without any problems. Only make about 3 to 5 hundred bales per year though
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 9:40am
Cut and spliced belts will work if they are all exactly the same length. They are just a bit noisy compared the endless ones.
I have a complete NOS set of upper and lower endless belts i would consider selling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 5:43pm
As long as the laces are clipper type laces, they will work fine.  You don't wanna use any of the more modern type laces, 'cause they are too stiff, and don't bend enough to go around the small rollers, that a roto-baler uses.  Google Hammond equipment, faunsdale, (ALA?), they can cut you the proper set, if you need'em...Wink
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 6:36pm
Back in the 70s we had to replace the roto bailer belts. We had picked something up ane cut one so put a laced belt on . It worked but not as good as the endless belts. At the end of the summer we put a full set of endless belts on. At the time we baled 6000 hay and 1000 straw bales each summer.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 9:23pm
Back in the 60s I would go out after work and replace a set of endless belts for 20.00 labor, if the owner would help me set the header off and on. About 1 1/2 hr.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 4:38am
one thing I forgot, of you are replacing laced betts, lace the new belt , to the old belt, and pull the old belt out, as you pull the new one in, saves a lot of time...Wink
