D17 Petronix swap??
PA185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Petronix swap??
    Posted: 17 Jul 2019 at 10:37am
Looking to upgrade my D17 series I to the petronix pointless ignition. Positive ground tractor (unsure if that affects anything) basically looking for the answer to some simple questions as I'm finding multiple answers to each.
1- 1.5 or 3ohm internal resistance coil?
2- resistor type or standard plug wires?
3- will it need an external ballast resistor?
If anyone has part numbers or a specific kit that would be great.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 11:04am
Bet Steve in NJ could answer your questions . Might wanna give him a call
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 12:05pm
switch to 12v neg ground.  3 ohm internal resisted coil, eliminates external one.  cant remember on plug wires,  think resisted
Edited by CAL(KS) - 17 Jul 2019 at 12:05pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 1:39pm
INfo above correct.  Switch to the negative ground.  The positive ground have a problem with no overvoltage protection and often die with too hot a charger/jumpstarter. Resistor wires (automotive style) preferred.   We stock all but the wires.
JIm D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 2:04pm
As Jim said, all correct info above. We have all in stock including the wires. I make the wire sets for each model Tractor. Resistor wires for the E.I. applications...
Steve@B&B
bb-customcircuits.com
This page was generated in 0.041 seconds.
