What is it
Tractor 1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor 1 Quote  Post ReplyReply Direct Link To This Post Topic: What is it
    Posted: 09 Jul 2019 at 8:15pm
I bought a B or C I'm assuming .
The Serial number is 78579.
Can anyone help.
Thank you !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 8:34pm
There should be a letter before that number.  Serial number is just in front of the gearshift.  Should read "Tractor No."....
Robert Mull Sr Georg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Sr Georg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 9:19pm
If the steering arm is pointing up out of the steering gear box it is a C if pointing down it is a B
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 9:26pm
It is not uncommon to see a C with a B transmission and vise versa
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 10:03pm
The shop manual that has sections for each might help identification:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 7:00am
Maybe post some pics of the tractor. Lots of folks on here will ID it real quick then.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:03am
A B is narrower (rear wheels) than a C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor 1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:42am
Thank you !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 3:11pm
A  "B" will have a gear box under the gas tank with the arm down as noted.. A "C" will have a gear box under the gas tank with the arm UP and  steering rod run to a second gear box under the radiator... The front wheels of a C can be narrow or wide front end, but always driven from this SECOND gear box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor 1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 3:42pm
Thank you !!
It's a B then. I appreciate it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 5:45pm
1949 model, if its a C...Wink
This page was generated in 0.227 seconds.
