D17 t/stat housing
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: D17 t/stat housing
    Posted: 15 Sep 2010 at 1:20pm
My D17 Ib started leaking antifreeze around the t/shat housing.  Looks like the gasket has cracked and partially squished out.
If I take it off and put on a new gasket, what should I do about torquing?  Since these are headbolts should I am concerned about what happens when I loosen only these two up.
I can get a torque wrench on the one, but the one under the stat housing you can't reach with a regular torque wrench.  Suppose I could use a crows foot to get at it and readjust the torque wrench setting for the extra length - is that how youse guys do it?
Do I loosen everything and retorque the whole head?  Or just these two?
thanks for your help and advice,
Creek
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 1:58pm
I just use a wrench and get them tightened by hand. if not a crow's foot would work just as good.
I would not mess with the other head bolts. just the two for the t-stat housing.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 1:59pm
for the torque setting, use this....
