Model 7000 |
Tom Crolwey
Topic: Model 7000Posted: 03 May 2019 at 1:38pm |
My 1976 maroon 7000 will not always start. By "playing" with the pto lever sometimes gets it to start. I replaced the neutral safety switch located behind the battery where the pto engages and disengages. But this did not help. Is there another safety switch, if there is I can't seem to find it. Any help is greatly appreciated. |
Thanks(1)
Posted: 03 May 2019 at 2:46pm |
Another safety switch under the floor mat and thru the cab floor for the clutch pedal.
Ron(AB)
Thanks(1)
Posted: 03 May 2019 at 10:50pm |
Welcome to the forum Tom!
The switches are probably good they just need to be adjusted. There is a contact plate on the clutch push rod that typically needs adjustment. You can see it when you look under the front of the cab behind the fuel tank filler cap. |
