WD Light Switch / Wiring
bhaynes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhaynes Quote  Post ReplyReply Direct Link To This Post Topic: WD Light Switch / Wiring
    Posted: 29 Apr 2019 at 12:03pm
Hey everybody. . . . AGAIN! :)
I feel like I 'bug' this forum way too much and on the simplest of things. I am needing a new light switch for my `47 WD. The old one was rusted and busted up, so I ripped it out. Steiner Tractor (who I am sure you guys know) has 2. But not sure what the difference is or which one to use?
Link 1 (3 position light switch)
https://www.steinertractor.com/ABC398-Universal-2-Position-Push-Pull-Ignition-and-Light-Switch
Also - Can I not just get a normal toggle switch from Auto Zone to use? I mean, all this is for, to my knowledge, is turning the headlights on and off. Eventually, I want to mount tail lights. But just like a car, once "on" - both headlights and taillights come on.
THANKS!! - And sorry to bother again.
Edited by bhaynes - 29 Apr 2019 at 12:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 12:13pm
Get it from Steve at B and B who's on here.  He knows exactly what you need.
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 3:26pm
Bill,
Sent you a PM. Check your inbox......
Steve@B&B
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 11:31am
The 3 position switch controls the charging output in addition to lights on/lights off.  If you have an original 6 volt charging system with a cutout rather than a voltage regulator, this will be important.
The three positions are: 1) In, low charge, lights off; 2) One notch out, high charge, lights on; and 3) Two notches out, high charge, lights off.  Generally speaking, if you are using the tractor regularly and not using any electric accessory, low charge is all you need when the lights are off.  If you have a battery that is not completely charged when you start it, you can run it on high charge for a while, but doing that too long will overcharge and at a minimum, boil off the water in the electrolyte.
The two position switch is just on-off.  If you have a voltage regulator, that will work fine.
Edited by HoughMade - 30 Apr 2019 at 11:33am
1951 B
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:46pm
bhaynes:
Just a word of encouragement,
You don't need to feel like you're bugging us at all as we all were beginners at one point and needed to ask a bunch of questions to gain understanding.
That's what makes this forum work so well, we know that by the questions that you ask, you're wanting clarification and information in order to make the right choice and decision for you.
And, we're all glad to answer you if we can in order to get you pointed in the right direction.
We do not mind at all how many questions you ask, as one day, you'll have enough knowledge and experience to answer others who are starting out on their projects, and asking a bunch of questions is the way to get there.
We're glad to see you and have you on board.
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:54pm
B,
 Jim is right. I still have Allis questions everyday!:)
BTW I have upgraded most of my tractors to be 12 volt, non standard electrical systems.
