WD starter removal |
Slowmotion ![]() Bronze Level ![]() Joined: 24 Mar 2019 Location: SW MO Points: 48 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Apr 2019 at 3:11pm |
I don't see what holds the starter on. Do you remove the plate on the back to get at whatever holds it? And then what?
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
Bolt on the side of housing take it out the whole way
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
That's the bolt with the locknut.....it has a tapered point that fits into a tapered hole in the starter housing.
garden_guy ![]() Orange Level ![]() Joined: 05 Jul 2013 Location: Illinois Points: 1151 |
Pretty easy. Jamb nut holds it in at one spot, and once you loosen that, you slide the starter straight out the back.
I see what look like two large, slot head screws on opposite sides of the starter.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Left side just ahead of the starter is a large set screw and jam nut. That is all that holds the starter in unless someone has messed with things. AaronSEIA
Grabbed a pic from the googles and put a bit of arrowing on it. Hope this helps. If yours looks somehow different, please provide a pic! ![]() |
I found it. It's very clear with that photo. That makes sense, and what I was looking at didn't. I tried to break the bolt loose with a box end wrench this evening, but couldn't. I'll try again tomorrow with a bigger wrench. It looks like it's been many moons since the starter has been off the tractor.
Thanks for all the help. |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
Between the air cleaner and headlight... |
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 969 |
Be very sure when you go to reinstall the starter that you back out the lock nut all the way so that the tapered bolt truly fastens the starter and then tighten the lock nut. On my one tractor I just discovered where the previous owner didn't back out the lock nut enough before tightening the bolt. The tapered bolt wasn't in all the way, this allowed for movement of the starter wearing the tapered hole bigger in the wrong direction and for some time the starter drive hasn't been engaging properly and consequently doing damage to the ring gear. This would have been so easy to prevent.
Break the nut loose before trying to break the bolt loose....that's why they call it a "lock" nut.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5026 |
If you have a 6 point deep socket, they work best to loosen the jam nut.
So what I'm looking at is a tapered bolt with a smaller head passing through a larger lock nut/jam nut? I've never encountered anything like that before. If I turn the larger nut, it looks like the bolt will have to turn with it. I don't understand how it works.
Loosen big nut first. Then remove bolt. You will understand after it is removed.👍
1957 WD45 dad's first AC
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 962 |
Here are a couple photos of the starter mounting setscrew and nut. It is possible that the nut will be rusted to the setscrew when you remove it and they can and will come out together at times. You can free them up after they are out. Clean the threads and coat with anti-seize before installing.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24704 |
On 2 of my D-14s, the bolt and nut came out as one unit. I put the bolt head in a vice ,then added some propane torch heat, some oil and carefully removed the nut. FIRST thing though... disconnect and remove battery from tractor !! Yeah, kinda obvious but I know someone who put a big wrech down on the MISSING battery box cover one day.. When you get the nut and bolt off, file any ridges on the tapers of the bolt. Also remove any paint,rust where the jam nut and the starter meet the cast iron. Jay
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
I think the nut takes a 1 1/16 socket. After removing tapered bolt and jam nut use a small pry bar to remove starter.
yeah, 1 1/16.. I have two BIG combo wrenches, one's always 'hiding'... needed to TAP the wrench with 4" hammer to free one of the bolts. That I remember, thinking ,yeesh what if the bolt breaks? They must be made outta REAL steel cause once free it was easy. Will need to 'wiggle' starter as it's a tight fit... Jay
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8528 |
Slow,
Your doing good!
If you have never seen one of these tapered, sq head, screw with the large jam nut, well welcome to the WD world of Allis. This was a favorite locking method for them. A little off topic but this is a partial list the places on a WD series that they exist: - Starter - crank pulley - belt pulley - I think there is a small one in the PTO box - small one in the hand clutch compartment Others? Regards, Chris |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2996 |
On my old D 15 starter the 11/16 lock bolt was rounded off . Using a 6 point socket is very good advice . Also I was told this bolt and locknut are not available new . Thanks
I'm pretty sure I've seen them reproduced in the DJS catalog.
AaronSEIA |
Haven't seen any in a catalog , but the good guy at Sandy Lake found a good used one for me . Thanks
Surprise, surprise! Everything came out easily. I bought a used starter from Sandy Lake and I'm wondering if there's anything I should know or do before installing it, such as lubricating it?
Clean any rust or paint from the hole that the starter fits into, and clean the outside diameter of the starter itself, where it contacts the housing. Then clean and polish up the stud making sure the tapered part is bare metal. Those points are where the starter grounds to the rest of the tractor, and paint or rust will only cause a slow crank situation by adding resistance. |
Assuming it's 6 volts.... use BIG,FAT, welder cable sized premade cables and NOT small,skinny 'car duty' battery cables... Be sure EVERY connection is clean ! Jay
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2473 |
sugarmaker
clutch petal length adjustment...
