190XT III
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT III
    Posted: 12 Apr 2019 at 8:50am
Hi every one I have been a regular reeder for about 4 years (ever sence I got my 55 WD45 going) and this past winter I rebuilt the engine on a non running 72 190XT III now I am having problems with the trans/power director when the tractor is cold I can start in 5,6,7,8th gear and it will strongly move then after about 10 mins of driving around the yard(no load about 1/3 throttle) it becomes "jumpy" and by about 15 mins wont move at all inless I put it in 4,3,2,1st gears origanly it didn't have steering intel I bled the air and cleaned the hydr splitting valve (big nut on back of hydr pump) new filters and fluids all around any ideas? thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:06am
How much "free-play" is there in the foot clutch pedal ??   Should be 4 inches or more.
ac fleet View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:24am
Trapped air in system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:38am
from what I can tell the foot clutch feels firm and looks about right
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:40am
if it was trapped air how would I go about bleeding it effectively,that would make sense to me from sitting for 3 years with lines disconnected and a new fluid flush
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:48am
also when I go into reverse it moves when the PD is N and when I put it into Low reverse it has a strong push towards neutral or High any ideal on that issue?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 10:16am
You aren't giving a good answer on the foot clutch. It sounds like to me you have zero freeplay and that ain't correct. There must be a MINIMUM of 2 inches freeplay and upwards of 4 inches is fine. ZERO freeplay could mean the foot clutch is slipping all because the adjustment under the hood is in need of correcting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 10:50am
good point I will go double check the travel tonight and see I assume your talking about adjusting the spring loaded pedal linking come off the flywheel housing to the pedal?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 11:07am
Yes. Lengthen to create more free-travel.
This page was generated in 0.523 seconds.
