road drag |
trace
Joined: 01 Aug 2012 Location: N.W. Iowa Points: 499 |
Topic: road dragPosted: 11 Apr 2019 at 10:02am |
anyone on here build their own drag to smooth out their gravel road? my grader operator has no concept of how to grade a road.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34856 |
Posted: 11 Apr 2019 at 10:05am |
Most grader men use a Scarifier edge on the main blade to drag up the packed rock and restore to a Bowl of Marbles, never have figured that out as to why. I use a Landscaper drag rake, can get or make wheel kit for depth control and set to angle to restore crown cut ditch bank.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24878 |
Posted: 11 Apr 2019 at 10:28am |
The late farmer from across the road would drag a set of tractor tire chains, up and down his laneway EVERY Sunday after church until brunch was ready, and he always had a GREAT driveway. The hydro employee who bought the farm hasn't figured how how to do it after 14-16 years....
trace
Posted: 11 Apr 2019 at 10:44am |
around here they use the scarifier to fix the washboard at intersections and stop signs. idiot that grades our road with his fancy caterpillar grader has never used it here in the 15 yrs we've lived here. like the tractor chain idea.
LOADER |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2317 |
Posted: 11 Apr 2019 at 11:13am |
Another cheap one is a couple combine rattle chains hooked together, the longer the better.
ac fleet
Posted: 11 Apr 2019 at 12:43pm |
Sale barn west of here used to have a bunch of chain link fence clamped to a heavy pipe with a cross tie on top for weight to keep the rock parking lot smooth , The lot was bout 8 acres. I would think that after you got the road smooth to start with, it wouldnt be hard to keep it that way with regular passes. A buddy of mine found an old homemade drag to work his 1/4 mile drive. It's just made from a bunch of worn out grader blades welded together and set at different angles and did have hand lift, which he converted to hyd. cyl. lift. ---I use a F-cub with a blade mounted under the little tractor. It does great for scratching the top, but no go for serious re-grading unless you spend a lot of time.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4974 |
Posted: 11 Apr 2019 at 12:44pm |
Large I beam or a length or railroad rail drug sideways
Edited by Pat the Plumber CIL - 11 Apr 2019 at 12:44pm |
Pat the Plumber CIL
Posted: 11 Apr 2019 at 12:57pm |
Trace , is this a public road ? Someone from Michigan posted a long time ago he used to go out and smooth, grade rock road in front of his house. There was an an accident involving some teenagers flying down the road at high speed. He was worried that someone would realise he was the one smoothing out the road and it might open him up for a liability. He stopped grading road after that . Sad the world is ruled by lawyers , just saying
ac fleet
Posted: 11 Apr 2019 at 1:16pm |
Trace!! I thought this was your drive, NOT public road!---IF public road do NOT do anything out there on it!!! You could be arrested by your local road people! Around here that is the way it works! Last winter I almost went to jail for pushing snow away from the end of my drive that the stupid county dumped in there. I had no where to go with it so I started a pile on the road ditch and it got over to the edge of the pavement before I got done. I had it 12' high with the skidloader and later that day county cops arrived due to a complaint from the county highway department about me creating a traffic hazard . --- These guys here are REAL azzholes, so you might want to be careful out there!!! Country is going nuts!! Good luck! Thanks ; ac fleet
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12324 |
Posted: 11 Apr 2019 at 1:42pm |
Yeah, as said, don't touch a public road, even as bad as you'd like to. It is against the law here in MI. Probably most states, liability centered laws.
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 11 Apr 2019 at 3:45pm |
The only way you could touch a public road is to go ask your road commissioner and be hired by him to do it.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
rrhead(SD)
Joined: 11 Sep 2009 Location: Canton, SD Points: 432 |
Posted: 11 Apr 2019 at 8:43pm |
I've been using a raddle chain out of my L3 for many years. Does the job for me. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8755 |
Posted: 11 Apr 2019 at 9:20pm |
Years ago, my father in law made a pull type grader out of an old truck frame. Stripped the frame down to just the two main rails and crossmembers, bolted a cutting edge onto the one rail, and put a cable on it to pull it (sideways). We still use it and it works great! Darrel
shameless dude
Posted: 12 Apr 2019 at 12:43am |
we use the old field harrows. the like 5x5 ft sections. always seem to suck when the hyd on my tractor would fail in certain places on the road. lol a couple years ago a local farmer used his road drag behind his 1950's year tractor, with a 3-pt. it's one of them red ones, think it was a "DRpower" that is advertised for small acreages, did a fantastic job, he did the road from section to section, sure beat the jobs that the county and their 1/4 million dollar road grader did! and it lasted!
farmboy520
Posted: 12 Apr 2019 at 7:16am |
Sometimes it not the equipment but the operator
shameless dude
Posted: 12 Apr 2019 at 3:25pm |
yeah...training operators in this county is about nil, they show how to start it, and then turn them loose in the yard to play for a couple days, then turn them loose on our roads. PffffT!
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6108 |
Posted: 14 Apr 2019 at 1:26am |
There's three really bad boils in my path between my driveway and the county blacktop to the south. One of them is hidden just past the crest of the hill when coming north, and it's bad enough so that all the farmers with 4wd trucks drive AROUND it... there's ruts 2' deep between crests 18" tall... enough so that the school busses get stuck going through it... yet the county has no intention of pounding a load of 3" rock into it... their answer was "running gravel trucks on it does more damage than good"... well, they've already dumped a bunch of rock on the areas that DON'T NEED IT... ![]() Couple sections of chain-link fence with a couple pieces of well casing wired to it make a fine gravel drag. |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 14 Apr 2019 at 7:53am |
Dave, sounds like you have frost boils. Other cause would be water standing in the ditch next to the road. Tis the season. Once the frost is all out, should get better. Yes a load of rock would help firm them up. But, like the county said, right now the trucks would do more damage than good. If they wait till it dries then blade it down and lay a couple loads of gravel over it and let traffic pack it all summer, it shouldn't be near as bad next year. Not the perfect fix, but, does help a lot. For ten years with previous jobs, I spent the month of June graveling township roads with a belly dump trailer.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3951 |
Posted: 14 Apr 2019 at 10:17am |
Here is the drag that came with my D17 when I bought it. It's made for a snap coupler setup. I've been using it for a few years now and it seems to do a good job. |
trace
Posted: 14 Apr 2019 at 3:30pm |
good lookin drag. gonna make something this year.
LOADER |
HD6GTOM
Posted: 15 Apr 2019 at 11:29pm |
Dad gum, who hires your road "engineers". The boys we have here are Great. But the only thing on the road they gots to grade is a lotta dirt mixed with a little rock. County supervisors are directly to blame for this. They spent over a million dollars on an old bank building just so they could have new offices. Bank building was worth less than $90000.00. There are 3 of these clowns, all from within the city limits. We have been trying to get this changed IE 1 from each corner of the county and 1 from that represents the cites and towns.
trace
Posted: 16 Apr 2019 at 8:06am |
just the grader operator tom. some of them are masters at the job, but this guy just don't seem to get it after over 10 years on the job. as far as wasting money. our city of 10,000 just bought an old bank building for a city hall and are putting 4.5 mil into it to get it ready while our streets are full of potholes. gotta get priorities straight, lol.
LOADER |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 16 Apr 2019 at 11:43am |
Be careful what you wish for. Over educated big city raised government jacka$$ ![]() ![]() ![]() ![]() ![]() ![]() . Thankfully only in town so far,![]() ![]() any new pavement come with obstacles in the middle of the road. One piece in town they put a ditch with rocks trees and plain old brush right down the middle. Was a nice wide street with parking both sides. In a hard rain it could run some water but never got into buildings. Now bicycle lane a narrow traffic lane ditch and the auto and bicycle lanes.![]() Another they going to make parking down the middle of the street. ![]() ![]() ![]() People are watching more after the other messes they have made. So this may be stopped,![]() but bureaucrats are hard to stop.This is pushed with grant money from the federal government. Which has stringes to the United Nations which wants us to be just
![]() ![]() ![]() ![]() another third world country.From something called Agenda 21.Edited by Ray54 - 16 Apr 2019 at 11:47am |
shameless dude
Posted: 17 Apr 2019 at 1:01am |
Douglas Co NE road dept puts on a school for other counties/cities on how to properly grade roads. been doing this for 40 years. is a very good school (a few days) worth. maybe talk to your county supts and try that?
shameless dude
Posted: 17 Apr 2019 at 1:02am |
last blizzard we had here, the city was busy clearing off a recreational walking path in and outside of the city, before they started clearing the streets! PffffT!
ac fleet
Posted: 17 Apr 2019 at 9:40am |
I used to grade all of the gravel roads for 2 townships way back in time. They even had me grade up the ditches and core new roads for the new gravel. When it came time for blacktop to go on they had me put final grade just before it went on. All of the roads were graded and crowned just enough so water ran off without taking the gravel. All of this was done with a 1956 Cat. 12 for Old town twp. and a 1962 Cat 12-e for Downs Twp.---That was before the fancy stuff they have now. You have to know what you are doing to run graders, and not everybody can do it. thanks; ac fleet
Edited by ac fleet - 17 Apr 2019 at 9:41am |
