Allis chalmers 816
sportster75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sportster75 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 816
    Posted: 01 Apr 2019 at 6:47pm
I'm looking for ring and pinion gears for my ac 816 backhoe, any help would be great it's a rockwell rear end. Ring gear has 37 teeth, pinion has 7 teeth.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2019 at 3:13am
Are any Case industrial/utility tractor rear end parts compatible? Case used Rockwell in their wheeled loaders.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2019 at 11:03pm
Case backhoes - 680E, 680G and 680H use the same Rockwell rear ends. Dynahoe as well, this Rockwell rear end was quite popular in the 70's and 80's. Even if some had a slightly different ratio, you can still put them in as long as you match the pinion and ring gears.
