B carb rebuild
2011dandd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Topic: B carb rebuild
    Posted: 07 Mar 2019 at 10:10am
Hi guys
Finally got around to rebuild the carb on the b.
I was wondering if anyone could explain something for me please. I have the zenith carb on mine and instead of having a main jet adjustment mine simply has the plug. I have no idea why ? Cheers folks hope someone can make sense of this
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 10:22am
On my Zenith B carbs the plug is where you can remove or swap main jets, could also be used to drain carburetor fuel bowl. Leon
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 1:49pm
Many of the earlier 'B's had the non-adjustable power jet with the plug.  The later models seem to all have the adjustable one.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 4:56pm
What year is the B, and what is the carb # on round brass tag riveted to the top of the carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 5:01pm
1947 English built b supplied with American parts.
It’s a dual fuel, ie petrol /tvo.
I need to inspect the identification plate better as some pleb has painted it in the past.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 5:09pm
Mine is a '51 and has the nonadjustable jet.  It's original.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 6:00pm
OEM Stock  1947 4 125 B (Kerosene) Zenith 161J7  906  216937-2  is what I find for your carb.
I believe it is type 161J7  model 906   part 216937-2.
Edited by chaskaduo - 07 Mar 2019 at 6:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 5:23am
Some model Zeniths have a "fixed" jet with the plug. These were designed specifically for certain early model Tractor applications. Some, of those (depending on their P/N) can be upgraded to the later cousins that have the adjustable enrichment jet feature. I've upgraded a few customer Carbs, but I have to go by the P/N in my Zenith book.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 5:55am
I will hopefully be able to get the part number from the carb later today!
Thanks everyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:34am
Hi
An update on the id plate number
The two numbers on there are
212844 and 9706
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 11:21am
My list has that as a 1941 B or C kerosene or low grade fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 11:36am
A 1941 b ? Really
I thought it was a 1947 I will have to check the tractor serial number now to see if that also tally’s up with a 1941 could have had a carb swap at some point though I guess.
Thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 3:47pm
Should be carburetor details in the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
